Saltar al contenido principal
Lenovo IdeaPad Flex 5-1470 Motherboard Replacement
Qué necesitas
  1. Lenovo IdeaPad Flex 5-1470 Motherboard Replacement, Back Panel: paso 1, imagen 1 de 1
    • Remove all ten 6.6 mm screws with a Phillips #00 screwdriver.
  2. Lenovo IdeaPad Flex 5-1470 Motherboard Replacement: paso 2, imagen 1 de 2 Lenovo IdeaPad Flex 5-1470 Motherboard Replacement: paso 2, imagen 2 de 2
    • Use the plastic opening tool to lift up and remove the casing.
  3. Lenovo IdeaPad Flex 5-1470 Motherboard Replacement, SSD: paso 3, imagen 1 de 1
    • Remove the single 3.6 mm screw using a Phillips #00 screwdriver.
    • The SSD will pop up on its own after removing the screw.
  4. Lenovo IdeaPad Flex 5-1470 Motherboard Replacement, Motherboard: paso 4, imagen 1 de 3 Lenovo IdeaPad Flex 5-1470 Motherboard Replacement, Motherboard: paso 4, imagen 2 de 3 Lenovo IdeaPad Flex 5-1470 Motherboard Replacement, Motherboard: paso 4, imagen 3 de 3
    • Use a Phillips #00 screwdriver to remove the three screws securing the fan.
    • Lift the fan up and out.
    • Use a Phillips #00 screwdriver to remove the three screws securing the hard drive.
    • Lift the hard drive up and out.
  5. Lenovo IdeaPad Flex 5-1470 Motherboard Replacement: paso 5, imagen 1 de 2 Lenovo IdeaPad Flex 5-1470 Motherboard Replacement: paso 5, imagen 2 de 2
    • Use a Phillips #00 screwdriver to remove the single screw securing the Wi-Fi card.
    • The Wi-Fi card will slightly lift away from the motherboard.
    • Pull the Wi-Fi card directly out of its port.
  6. Lenovo IdeaPad Flex 5-1470 Motherboard Replacement: paso 6, imagen 1 de 2 Lenovo IdeaPad Flex 5-1470 Motherboard Replacement: paso 6, imagen 2 de 2
    • Use a Phillips #00 screwdriver to remove the three screws securing the motherboard.
    • Gently disconnect the cables and ribbon cables connected to the motherboard.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 34
Todo El Tiempo: 418
