Saltar al contenido principal
Lenovo IdeaPad Flex 5-1470 Display Replacement
Qué necesitas
  1. Lenovo IdeaPad Flex 5-1470 Display Replacement, Back Panel: paso 1, imagen 1 de 1
    • Remove all ten 6.6 mm screws with a Phillips #00 screwdriver.
  2. Lenovo IdeaPad Flex 5-1470 Display Replacement: paso 2, imagen 1 de 2 Lenovo IdeaPad Flex 5-1470 Display Replacement: paso 2, imagen 2 de 2
    • Use the plastic opening tool to lift up and remove the casing.
  3. Lenovo IdeaPad Flex 5-1470 Display Replacement, Motherboard: paso 3, imagen 1 de 3 Lenovo IdeaPad Flex 5-1470 Display Replacement, Motherboard: paso 3, imagen 2 de 3 Lenovo IdeaPad Flex 5-1470 Display Replacement, Motherboard: paso 3, imagen 3 de 3
    • Use a Phillips #00 screwdriver to remove the three screws securing the fan.
    • Lift the fan up and out.
    • Use a Phillips #00 screwdriver to remove the three screws securing the hard drive.
    • Lift the hard drive up and out.
  4. Lenovo IdeaPad Flex 5-1470 Display Replacement: paso 4, imagen 1 de 2 Lenovo IdeaPad Flex 5-1470 Display Replacement: paso 4, imagen 2 de 2
    • Use a Phillips #00 screwdriver to remove the single screw securing the Wi-Fi card.
    • The Wi-Fi card will slightly lift away from the motherboard.
    • Pull the Wi-Fi card directly out of its port.
  5. Lenovo IdeaPad Flex 5-1470 Display Replacement: paso 5, imagen 1 de 2 Lenovo IdeaPad Flex 5-1470 Display Replacement: paso 5, imagen 2 de 2
    • Use a Phillips #00 screwdriver to remove the three screws securing the motherboard.
    • Gently disconnect the cables and ribbon cables connected to the motherboard.
  6. Lenovo IdeaPad Flex 5-1470 Display Replacement, Display: paso 6, imagen 1 de 1
    • Use a Phillips #00 screwdriver to remove the four 5 mm screws from the left and right hinges (two screws on each hinge).
  7. Lenovo IdeaPad Flex 5-1470 Display Replacement: paso 7, imagen 1 de 3 Lenovo IdeaPad Flex 5-1470 Display Replacement: paso 7, imagen 2 de 3 Lenovo IdeaPad Flex 5-1470 Display Replacement: paso 7, imagen 3 de 3
    • Disconnect the display assembly from the rest of the device by separating the hinges of the display from the body of the laptop.
    • Use a spudger to carefully pry loose the two screw covers (one on each hinge).
    • Use a Phillips #00 screwdriver to remove the two 3 mm screws from the display (one on each side).
  8. Lenovo IdeaPad Flex 5-1470 Display Replacement: paso 8, imagen 1 de 2 Lenovo IdeaPad Flex 5-1470 Display Replacement: paso 8, imagen 2 de 2
    • Use a heat gun or an iOpener to lightly heat the outer edges of the display, loosening the adhesive strips.
    • Wedge a Jimmy or opening picks between the display and display housing, then carefully pry around the entire perimeter until the display separates from the housing.
  9. Lenovo IdeaPad Flex 5-1470 Display Replacement: paso 9, imagen 1 de 1
    • Disconnect the display ribbon cable.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 48
Todo El Tiempo: 1,604
