Saltar al contenido principal
Lenovo IdeaPad 330S Fan and Thermal Unit
Qué necesitas
  1. Lenovo IdeaPad 330S Fan and Thermal Unit, Removing bottom case: paso 1, imagen 1 de 2 Lenovo IdeaPad 330S Fan and Thermal Unit, Removing bottom case: paso 1, imagen 2 de 2
    • Turn off the device and disconnect from the power.
    • Remove the 10 screws as shown in picture.
    • Using a plastic pry tool remove the bottom case (gently).
  2. Lenovo IdeaPad 330S Fan and Thermal Unit, Disconnecting Battery: paso 2, imagen 1 de 1
    • Using a spudger gently push the black connector to the left (red circle).
    • If you want to remove the battery by removing the five screws labeled in blue.
  3. Lenovo IdeaPad 330S Fan and Thermal Unit, Removing guard shield: paso 3, imagen 1 de 2 Lenovo IdeaPad 330S Fan and Thermal Unit, Removing guard shield: paso 3, imagen 2 de 2
    • Remove the 3 screws that are circuled in blue. Then remove the red one.
    • The red circle is a M2.5 and the blue circle are M2.0 those are different screws!
    • Remove the black shield
  4. Lenovo IdeaPad 330S Fan and Thermal Unit, Removing Cooling Fan: paso 4, imagen 1 de 1
    • Remove the two black screws that are marked in red
    • Disconnect the fan (blue marker) from MB by pushing gently to the left using a spudger.
  5. Lenovo IdeaPad 330S Fan and Thermal Unit, Removing the Thermal unit: paso 5, imagen 1 de 1
    • Remove the 6 screws in revrse of the number stated on screws.
    • Replace the thermal paste with a fresh one
    • Removing the fan is not needed but will help with easier dissemble of thermal unit
Conclusión
3 personas más completaron esta guía.
Ilia Tocheny
Miembro Desde 04/30/19
1,616 Reputación
9 Guías creadas
2 comentarios
I want to buy this piece, where can I find it for purchase?
c.lobos_7 - Contestar
Good question, you could try at your local Lenovo Service provider.
Ilia Tocheny - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 17
Todo El Tiempo: 1,598
