Saltar al contenido principal
Lenovo IdeaPad 300-17ISK Hard Drive Replacement
Qué necesitas
  1. Lenovo IdeaPad 300-17ISK Hard Drive Replacement, Bottom Back Cover: paso 1, imagen 1 de 1
    • Unscrew the two 7mm Phillips #1 screws that hold the bottom back plate in its place.
  2. Lenovo IdeaPad 300-17ISK Hard Drive Replacement: paso 2, imagen 1 de 2 Lenovo IdeaPad 300-17ISK Hard Drive Replacement: paso 2, imagen 2 de 2
    • Place your hands at the bottom of the cover and slide it towards you.
    • Lift the cover up to remove it.
  3. Lenovo IdeaPad 300-17ISK Hard Drive Replacement, Hard Drive: paso 3, imagen 1 de 1
    • The hard drive is located at the bottom of the laptop.
  4. Lenovo IdeaPad 300-17ISK Hard Drive Replacement: paso 4, imagen 1 de 1
    • Unscrew the four 6mm Phillips #1 screws that hold the hard drive frame in place.
  5. Lenovo IdeaPad 300-17ISK Hard Drive Replacement: paso 5, imagen 1 de 1
    • Gently pick up the hard drive without pulling it completely out.
    • You shouldn't use excessive force because the hard drive is still attached to the motherboard.
  6. Lenovo IdeaPad 300-17ISK Hard Drive Replacement: paso 6, imagen 1 de 2 Lenovo IdeaPad 300-17ISK Hard Drive Replacement: paso 6, imagen 2 de 2
    • Use the spudger to disconnect the hard drive from it motherboard connector.
    • The connector should come right off without excessive force.
  7. Lenovo IdeaPad 300-17ISK Hard Drive Replacement: paso 7, imagen 1 de 2 Lenovo IdeaPad 300-17ISK Hard Drive Replacement: paso 7, imagen 2 de 2
    • Remove the four 3mm Phillips #1 screws, two on each side, that secure the hard drive in its protective frame.
    • These screws are different from the rest of the laptop screws. You can damage the drive using the wrong screws.
    • Lift the frame to separate it from the hard drive.
Conclusión
10 personas más completaron esta guía.
Ammar Dodin
Miembro Desde 01/19/17
1,057 Reputación
6 Guías creadas
Equipo
UC Davis, Team 1-3, Rodger Winter 2017 Miembro de UC Davis, Team 1-3, Rodger Winter 2017
UCD-RODGER-W17S1G3
4 Miembros
6 Guías creadas
3 comentarios
Clear and easy - thanks!
Beth Pierce - Contestar
Very good and to the point
al_stewart - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 50
Todo El Tiempo: 9,685
