Saltar al contenido principal
Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement
Qué necesitas
  1. Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement, Lower Case: paso 1, imagen 1 de 1
    • First, before you do anything, make sure the computer has been turned off and unplugged.
    • Place the the computer bottom facing up. Unscrew the eleven 6 mm screws using a Phillips #0 screwdriver.
  2. Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement: paso 2, imagen 1 de 2 Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement: paso 2, imagen 2 de 2
    • Use an opening tool to gently disconnect the clips on the side of the back panel.
    • DO NOT try to force open the panel, as this may cause damage to it.
  3. Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement: paso 3, imagen 1 de 2 Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement: paso 3, imagen 2 de 2
    • Pry out the optical drive opposite of the laptop.
    • Since the screws have already been removed, you will not need to worry about any more screws on the optical drive.
  4. Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement: paso 4, imagen 1 de 3 Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement: paso 4, imagen 2 de 3 Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement: paso 4, imagen 3 de 3
    • Release the remaining clasp and remove the lower case.
  5. Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement, Hard Disk Drive (HDD): paso 5, imagen 1 de 1
    • Use a Phillips #1 screwdriver to unscrew the four 5 mm screws that are holding the hard drive in place.
  6. Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement: paso 6, imagen 1 de 2 Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement: paso 6, imagen 2 de 2
    • Do not lift the hard drive straight up; this might break the connection port.
    • Softly slide the hard drive away from the port.
  7. Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement: paso 7, imagen 1 de 2 Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement: paso 7, imagen 2 de 2
    • Use a Phillips #1 screwdriver remove the 2 screws from both sides of the hard drive (total of 4 screws).
  8. Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement: paso 8, imagen 1 de 1
    • Remove the hard drive from the housing mount.
Conclusión
Cameron Mounce
Miembro Desde 09/05/23
668 Reputación
5 Guías creadas
Equipo
Gateway, Team 1-3, Pee Fall 2023 Miembro de Gateway, Team 1-3, Pee Fall 2023
GCC-PEE-F23S1G3
4 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 13
Todo El Tiempo: 119
