Saltar al contenido principal
Lenovo IdeaPad 110-15ISK Hard Drive Replacement
Qué necesitas
  1. Lenovo IdeaPad 110-15ISK Hard Drive Replacement, Back Keyboard Screws: paso 1, imagen 1 de 1
    • Remove the two keyboard screws on the back of the device(the two on the same row)
  2. Lenovo IdeaPad 110-15ISK Hard Drive Replacement, Remove the Keyboard: paso 2, imagen 1 de 1
    • Insert a prying tool in the crack between the keyboard and frame. Start by the power button and go all the way round the keyboard.
  3. Lenovo IdeaPad 110-15ISK Hard Drive Replacement, Keyboard Ribbon Cable: paso 3, imagen 1 de 1
    • Remover the ribbon cable and remove the keyboard afterward.
  4. Lenovo IdeaPad 110-15ISK Hard Drive Replacement, Under Keyboard: paso 4, imagen 1 de 1
    • After the keyboard is removed, remove the screw and the battery connector.
  5. Lenovo IdeaPad 110-15ISK Hard Drive Replacement, Disk Drive: paso 5, imagen 1 de 1
    • Remove the screw that is under the two keyboard screws and pull the disk drive out.
  6. Lenovo IdeaPad 110-15ISK Hard Drive Replacement, Outer Screws: paso 6, imagen 1 de 1
    • Remove all of the screws on the outside edge of the bottom.
  7. Lenovo IdeaPad 110-15ISK Hard Drive Replacement, Separating the Case: paso 7, imagen 1 de 1
    • Flip the laptop over and in the crack between the two case pieces slide a prying tool in between and follow the perimeter until the two pieces are separated.
  8. Lenovo IdeaPad 110-15ISK Hard Drive Replacement, Drive Bay: paso 8, imagen 1 de 1
    • Remove the four screws securing the drive bay into the case.
  9. Lenovo IdeaPad 110-15ISK Hard Drive Replacement, Removing the Drive: paso 9, imagen 1 de 1
    • Remove the four screws the hold the metal cage onto the drive to separate them.
Conclusión
Una persona más ha completado esta guía.
Stuart Luhigo
Miembro Desde 11/20/18
169 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 8
Todo El Tiempo: 513
