Saltar al contenido principal
Lenovo Flex 6-11IGM Display Replacement
Qué necesitas
  1. Lenovo Flex 6-11IGM Display Replacement, Display: paso 1, imagen 1 de 2 Lenovo Flex 6-11IGM Display Replacement, Display: paso 1, imagen 2 de 2
    • Place the laptop face-up.
    • Open the laptop.
  2. Lenovo Flex 6-11IGM Display Replacement: paso 2, imagen 1 de 1
    • Using a plastic opening pick, begin to gently separate the display from the case, moving around the edge.
    • Using the plastic opening pick, begin to gently separate the plastic trim from the case, moving around the edge.
  3. Lenovo Flex 6-11IGM Display Replacement: paso 3, imagen 1 de 1
    • Using a Phillips #00 screwdriver, remove the three 2.5 mm screws that secure the display.
    • Secure a suction cup to the screen and pull it free from the upper case with light force.
    • Rest the display on the keyboard.
  4. Lenovo Flex 6-11IGM Display Replacement: paso 4, imagen 1 de 2 Lenovo Flex 6-11IGM Display Replacement: paso 4, imagen 2 de 2
    • Disengage the cable located at the bottom of the display.
    • Slide a plastic opening pick under the brown bar, lifting the bar up, and disengage the wire with your fingers.
    • Disengage the cable at the bottom left of the display with your fingers.
    • Disengage the cable at the top center of the display using your fingers and remove the cable from the display housing.
  5. Lenovo Flex 6-11IGM Display Replacement: paso 5, imagen 1 de 1
    • Remove the display.
Conclusión
Una persona más ha completado esta guía.
Un comentario
Can you replace the digitizer separately? Or do you have to get the digitizer and lcd combo for replacement? Is it worth it at $130 for the replacement? Laptop is only a couple years old…
Tyson Strickland - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 12
Todo El Tiempo: 617
