Introducción
The Lenovo G560 has a 6-cell battery that fits snugly on the underside of the computer, directly under the screen. Battery removal is considered a crucial first step to any further repair or disassembly.
Turn off the computer.
  • Turn off the computer.
  • Disconnect the charging cable from the computer.
  • Failure to unplug the cable could result in electric shock.
  • Flip the computer upside down.
Agregar Comentario
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Locate the two switches that lock the battery. Push the right-hand switch outward into the "unlocked" position. Locate the two switches that lock the battery. Push the right-hand switch outward into the "unlocked" position.
  • Locate the two switches that lock the battery. Push the right-hand switch outward into the "unlocked" position.
Agregar Comentario
Push and hold the left hand switch outward in the "unlocked" position, then gently slide the battery away from the computer.
  • Push and hold the left hand switch outward in the "unlocked" position, then gently slide the battery away from the computer.
Agregar Comentario
Conclusión
To reassemble your battery, line up the battery and slide it in until the second lock (left hand switch) clicks. Then lock the 1st switch.
9 personas más completaron esta guía.
Dennis Wong
Miembro Desde 11/01/13
468 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 18-40, Regan Winter 2013 Miembro de Cal Poly, Team 18-40, Regan Winter 2013
CPSU-REGAN-W13S18G40
5 Miembros
7 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 6
Últimos 30 Días: 26
Todo El Tiempo: 3,787
