Introducción
How to disassemble the device and replace / upgrade Hard Disk Drive with SSD, SO-DIMM memory modules, WiFi / Wireless card M.2 aka NGFF (Next Generation Form Factor) and CMOS Battery (Complementary Metal-Oxide-Semiconductor (CMOS), Real-Time Clock (RTC)).
Qué necesitas
Resumen del Video
Remove the screws securing the Memory / HDD cover.
Slide the cover down and remove it.
To pop up the memory module you’ll have to spread latches on both sides of the slot.
Speed 1600 MHz / PC3L-12800
Technology DDR3L SDRAM SODIMM
Max Supported Size 16 GB
Form Factor SO-DIMM 204-pin
Slots Qty 2
Empty Slots 1
Remove two screws securing the hard drive mounting bracked.
Slide the HDD to the left to disconnect it from the motherboard and remove it from the device.
Remove two screws on each side of the HDD to remove the mounting bracket.
Now you have to transfer the mounting bracket to the new HDD or SSD.
Remove the screw and disconnect the two coaxial antenna cables from the WiFi card.
Pop it up and remove it from the slot.
Complementary Metal-Oxide-Semiconductor (CMOS) aka Real-Time Clock (RTC)
3 personas más completaron esta guía.
