Saltar al contenido principal
Lenovo 300e Chromebook Motherboard Replacement
Qué necesitas
  1. Lenovo 300e Chromebook Motherboard  Replacement, Back Cover: paso 1, imagen 1 de 3 Lenovo 300e Chromebook Motherboard  Replacement, Back Cover: paso 1, imagen 2 de 3 Lenovo 300e Chromebook Motherboard  Replacement, Back Cover: paso 1, imagen 3 de 3
    • Remove eleven 5 mm screws from the back of the computer using a Phillips #2 screwdriver.
  2. Lenovo 300e Chromebook Motherboard  Replacement: paso 2, imagen 1 de 3 Lenovo 300e Chromebook Motherboard  Replacement: paso 2, imagen 2 de 3 Lenovo 300e Chromebook Motherboard  Replacement: paso 2, imagen 3 de 3
    • Use a spudger along the edge of the Chromebook to gently remove the back cover of the laptop.
  3. Lenovo 300e Chromebook Motherboard  Replacement, Battery: paso 3, imagen 1 de 3 Lenovo 300e Chromebook Motherboard  Replacement, Battery: paso 3, imagen 2 de 3 Lenovo 300e Chromebook Motherboard  Replacement, Battery: paso 3, imagen 3 de 3
    • Remove six 3 mm screws from the battery with a Phillips #2 screwdriver.
  4. Lenovo 300e Chromebook Motherboard  Replacement: paso 4, imagen 1 de 3 Lenovo 300e Chromebook Motherboard  Replacement: paso 4, imagen 2 de 3 Lenovo 300e Chromebook Motherboard  Replacement: paso 4, imagen 3 de 3
    • Disconnect the wiring harness that connects the battery to the motherboard.
    • Lift the battery up and out of the laptop.
  5. Lenovo 300e Chromebook Motherboard  Replacement, Motherboard: paso 5, imagen 1 de 2 Lenovo 300e Chromebook Motherboard  Replacement, Motherboard: paso 5, imagen 2 de 2
    • Remove the three silver 3 mm screws from the center of the metal cover using a Phillips #00 screwdriver.
  6. Lenovo 300e Chromebook Motherboard  Replacement: paso 6, imagen 1 de 3 Lenovo 300e Chromebook Motherboard  Replacement: paso 6, imagen 2 de 3 Lenovo 300e Chromebook Motherboard  Replacement: paso 6, imagen 3 de 3
    • Remove two 3 mm screws from the top of the metal cover using a Phillips #2 screwdriver.
    • Remove the metal cover from the laptop.
  7. Lenovo 300e Chromebook Motherboard  Replacement: paso 7, imagen 1 de 3 Lenovo 300e Chromebook Motherboard  Replacement: paso 7, imagen 2 de 3 Lenovo 300e Chromebook Motherboard  Replacement: paso 7, imagen 3 de 3
    • Remove the nine 3 mm screws from the motherboard using a Phillips #2 screwdriver.
    • Detach all the connectors from the motherboard.
  8. Lenovo 300e Chromebook Motherboard  Replacement: paso 8, imagen 1 de 3 Lenovo 300e Chromebook Motherboard  Replacement: paso 8, imagen 2 de 3 Lenovo 300e Chromebook Motherboard  Replacement: paso 8, imagen 3 de 3
    • Remove the tape using a spudger.
    • Disconnect the large cable connector.
    • Remove the motherboard from the laptop.
Conclusión
Un comentario
where is the write protect screw located im trying to install windows on this model
Harvey Willis - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 6
Ultimos 30 días: 45
Todo El Tiempo: 1,234
