Saltar al contenido principal
LG env2 vx9100 Side Buttons Replacement
Qué necesitas
  1. LG env2 vx9100 Side Buttons Replacement, Battery: paso 1, imagen 1 de 3 LG env2 vx9100 Side Buttons Replacement, Battery: paso 1, imagen 2 de 3 LG env2 vx9100 Side Buttons Replacement, Battery: paso 1, imagen 3 de 3
    • Before disassembling your phone, be sure it is powered off to avoid minor electric shock or possible fire.
    • Place the phone face down on the table.
    • Use your fingernail or an opening tool to pull down the tab below the battery.
    • Lift the battery out.
  2. LG env2 vx9100 Side Buttons Replacement, Back Panel: paso 2, imagen 1 de 2 LG env2 vx9100 Side Buttons Replacement, Back Panel: paso 2, imagen 2 de 2
    • Locate the five rubber covers on the back panel of the phone.
    • Use the metal probe to pop out each rubber cover to reveal the screws underneath.
  3. LG env2 vx9100 Side Buttons Replacement: paso 3, imagen 1 de 2 LG env2 vx9100 Side Buttons Replacement: paso 3, imagen 2 de 2
    • Locate the six 2.5mm screws on the back panel of the phone.
    • Use a #00 Phillips screwdriver to remove each 2.5mm screw.
  4. LG env2 vx9100 Side Buttons Replacement: paso 4, imagen 1 de 2 LG env2 vx9100 Side Buttons Replacement: paso 4, imagen 2 de 2
    • Locate the seam around the edge of the phone.
    • Insert the plastic opening tool into the seam and pry gently to release the tabs.
    • Work your way around the phone until all tabs are released.
    • Remove the back panel of the phone.
  5. LG env2 vx9100 Side Buttons Replacement, Side Buttons: paso 5, imagen 1 de 2 LG env2 vx9100 Side Buttons Replacement, Side Buttons: paso 5, imagen 2 de 2
    • Locate the volume and camera buttons on the right side of the phone.
    • Lift up on the buttons to slide them out of the phone.
Conclusión
Reed Williston
Miembro Desde 09/26/12
34 Reputación
7 Guías creadas
Equipo
Cal Poly, Team 16-55, Forte Fall 2012 Miembro de Cal Poly, Team 16-55, Forte Fall 2012
CPSU-FORTE-F12S16G55
5 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 476
