Saltar al contenido principal
LG env2 vx9100 Front Keyboard Replacement
Qué necesitas
  1. LG env2 vx9100 Front Keyboard Replacement, Battery: paso 1, imagen 1 de 3 LG env2 vx9100 Front Keyboard Replacement, Battery: paso 1, imagen 2 de 3 LG env2 vx9100 Front Keyboard Replacement, Battery: paso 1, imagen 3 de 3
    • Before disassembling your phone, be sure it is powered off to avoid minor electric shock or possible fire.
    • Place the phone face down on the table.
    • Use your fingernail or an opening tool to pull down the tab below the battery.
    • Lift the battery out.
  2. LG env2 vx9100 Front Keyboard Replacement, Back Panel: paso 2, imagen 1 de 2 LG env2 vx9100 Front Keyboard Replacement, Back Panel: paso 2, imagen 2 de 2
    • Locate the five rubber covers on the back panel of the phone.
    • Use the metal probe to pop out each rubber cover to reveal the screws underneath.
  3. LG env2 vx9100 Front Keyboard Replacement: paso 3, imagen 1 de 2 LG env2 vx9100 Front Keyboard Replacement: paso 3, imagen 2 de 2
    • Locate the six 2.5mm screws on the back panel of the phone.
    • Use a #00 Phillips screwdriver to remove each 2.5mm screw.
  4. LG env2 vx9100 Front Keyboard Replacement: paso 4, imagen 1 de 2 LG env2 vx9100 Front Keyboard Replacement: paso 4, imagen 2 de 2
    • Locate the seam around the edge of the phone.
    • Insert the plastic opening tool into the seam and pry gently to release the tabs.
    • Work your way around the phone until all tabs are released.
    • Remove the back panel of the phone.
  5. LG env2 vx9100 Front Keyboard Replacement, Front Panel: paso 5, imagen 1 de 2 LG env2 vx9100 Front Keyboard Replacement, Front Panel: paso 5, imagen 2 de 2
    • Use a spudger to pry the two rubber covers out of the device.
  6. LG env2 vx9100 Front Keyboard Replacement: paso 6, imagen 1 de 2 LG env2 vx9100 Front Keyboard Replacement: paso 6, imagen 2 de 2
    • Use a Phillips #00 screwdriver to remove two 2.5 mm screws.
  7. LG env2 vx9100 Front Keyboard Replacement: paso 7, imagen 1 de 2 LG env2 vx9100 Front Keyboard Replacement: paso 7, imagen 2 de 2
    • These screws will not be visible or accessible unless the two sides of the phone are at approximately 90 degrees relative to each other.
  8. LG env2 vx9100 Front Keyboard Replacement: paso 8, imagen 1 de 2 LG env2 vx9100 Front Keyboard Replacement: paso 8, imagen 2 de 2
    • Insert the plastic opening tool in the crease and move it along each edge of the phone.
    • Separate the front panel from the rest of the phone.
    • Be careful not to damage the orange ribbon that connects to the motherboard through the hinge in the phone. If the ribbon is damaged, the phone will not function properly.
    • Open the phone to reveal the inside monitor.
  9. LG env2 vx9100 Front Keyboard Replacement: paso 9, imagen 1 de 3 LG env2 vx9100 Front Keyboard Replacement: paso 9, imagen 2 de 3 LG env2 vx9100 Front Keyboard Replacement: paso 9, imagen 3 de 3
    • Use a Phillips #00 screwdriver to remove two 2.5mm screws.
    • Using your hands, separate the front panel from the phone by carefully pulling it straight off.
  10. LG env2 vx9100 Front Keyboard Replacement, Front Keyboard: paso 10, imagen 1 de 2 LG env2 vx9100 Front Keyboard Replacement, Front Keyboard: paso 10, imagen 2 de 2
    • Place the front panel so that the buttons face upwards.
    • Push on the buttons to remove the keyboard from the front cover.
Conclusión
2 personas más completaron esta guía.
Reed Williston
Miembro Desde 09/26/12
34 Reputación
7 Guías creadas
Equipo
Cal Poly, Team 16-55, Forte Fall 2012 Miembro de Cal Poly, Team 16-55, Forte Fall 2012
CPSU-FORTE-F12S16G55
5 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 10
Todo El Tiempo: 783
