Introducción
In this guide you will be removing the back panel to access the motherboard. Once you have reached the motherboard you will remove the camera lens from the motherboard.
Partes
No se requieren partes.
Before dissembling your phone, be sure it is powered off to avoid minor electric shock or possible fire. Place the phone facedown on the table. Use your fingernail (or a small screw driver) to pull down the tab below the battery.
  • Before dissembling your phone, be sure it is powered off to avoid minor electric shock or possible fire.
  • Place the phone facedown on the table.
  • Use your fingernail (or a small screw driver) to pull down the tab below the battery.
  • Lift the battery out.
Agregar Comentario
Locate the five rubber covers on the back panel of the phone. Use the metal probe to pop out each rubber cover to reveal the screws underneath.
  • Locate the five rubber covers on the back panel of the phone.
  • Use the metal probe to pop out each rubber cover to reveal the screws underneath.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Locate the six 2.5mm screws on the back panel of the phone. Use a #00 Phillips screwdriver to remove each 2.5mm screw.
  • Locate the six 2.5mm screws on the back panel of the phone.
  • Use a #00 Phillips screwdriver to remove each 2.5mm screw.
Agregar Comentario
Locate the seam around the edge of the phone. Insert the plastic opening tool into the seam and pry gently to release the tabs.
  • Locate the seam around the edge of the phone.
  • Insert the plastic opening tool into the seam and pry gently to release the tabs.
  • Work your way around the phone until all tabs are released.
  • Remove the back panel of the phone.
Agregar Comentario
Locate the ribbon attached to the lens of the camera. Place the plastic opening tool in between the logic board and ribbon.
  • Locate the ribbon attached to the lens of the camera.
  • Place the plastic opening tool in between the logic board and ribbon.
  • Lift up the plastic opening to detach the ribbon from the logic board.
Agregar Comentario
Place the plastic opening tool in between the lens and the logic board. Detach the lens from the logic board using the plastic opening tool by popping it out.
  • Place the plastic opening tool in between the lens and the logic board.
  • Detach the lens from the logic board using the plastic opening tool by popping it out.
  • Take the entire lens and ribbon off of the logic board.
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Reed Williston
Miembro Desde 26/09/12
22 Reputación
14 Guías creadas
Equipo
Cal Poly, Team 16-55, Forte Fall 2012 Miembro de Cal Poly, Team 16-55, Forte Fall 2012
CPSU-FORTE-F12S16G55
5 Miembros
14 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 365
