Introducción
The keyboard is placed on the motherboard but is not attached in any way. This step is easy because there are no necessary tools involved. It is a simple and easy step that allows you to clean the keyboard.
Qué necesitas
Using your index finger, pull the top of the battery out first. Place your finger at the top center of the battery in the gap that is provided. Then pull the battery towards yourself.
The battery should easily fall out after the top of the battery has been pulled out.
Unscrew the six 2.4mm Phillips #00 screws (three on the left and three on the right of the phone) to remove the inner back case.
Turn the motherboard over and carefully remove the keypad from the motherboard.
The keyboard may be sitting loosely in the case (not attached to the motherboard). Carefully remove keyboard from case.
Una persona más ha completado esta guía.
