Saltar al contenido principal
LG Voyager Micro SD Replacement
Qué necesitas
  1. LG Voyager Micro SD Replacement, Micro SD: paso 1, imagen 1 de 1
    • Turn the phone onto its side so the label micro SD is facing upside down.
    • Once on its side, lift the micro SD cover up and swivel it away from the opening.
  2. LG Voyager Micro SD Replacement: paso 2, imagen 1 de 2 LG Voyager Micro SD Replacement: paso 2, imagen 2 de 2
    • The Micro SD card will appear as a thin plastic piece sticking out of the phone
    • Gently push down on the card, you should hear a click, and then it will "spring" back at you.
    • The card should be sticking out of the phone slightly once this is done.
    • Remove the card from the slot
Conclusión
Michelle
Miembro Desde 04/10/12
20 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 17-26, Amido Spring 2012 Miembro de Cal Poly, Team 17-26, Amido Spring 2012
CPSU-AMIDO-S12S17G26
4 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 11
Todo El Tiempo: 401
