Partes
No se requieren partes.
Turn the phone onto its side so the label micro SD is facing upside down.
  • Turn the phone onto its side so the label micro SD is facing upside down.
  • Once on its side, lift the micro SD cover up and swivel it away from the opening.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
The Micro SD card will appear as a thin plastic piece sticking out of the phone Gently push down on the card, you should hear a click, and then it will "spring" back at you.
  • The Micro SD card will appear as a thin plastic piece sticking out of the phone
  • Gently push down on the card, you should hear a click, and then it will "spring" back at you.
  • The card should be sticking out of the phone slightly once this is done.
  • Remove the card from the slot
Agregar Comentario
Conclusión
Michelle
Miembro Desde 10/04/12
17 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 17-26, Amido Spring 2012 Miembro de Cal Poly, Team 17-26, Amido Spring 2012
CPSU-AMIDO-S12S17G26
4 Miembros
5 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 2
Todo El Tiempo: 302
