Introducción
The LCD screens are connected as one unit, and therefore should be removed together.
Partes
No se requieren partes.
Remove the two triangular pads at the top of the two speakers.
  • Remove the two triangular pads at the top of the two speakers.
  • These pads have adhesive to keep them situated, so you may want to use a fine-tipped object, such as a screwdriver or a pen, to remove them. It is easiest to place the fine-tipped object in the small indent in the corner of these pads.
Agregar Comentario
Remove the two rubber cylinders from their shafts. These cover more screws.
  • Remove the two rubber cylinders from their shafts. These cover more screws.
  • This requires a little more effort, so you may need to "dig" them out.
Agregar Comentario
Now remove the four screws.
  • Now remove the four screws.
  • The screws are small, so put them somewhere that you can easily keep track of them.
Agregar Comentario
Starting on the side with blue square, pry the faceplate upwards with the flat end of a spudger.
  • Starting on the side with blue square, pry the faceplate upwards with the flat end of a spudger.
    • Continue to slide the flat edge along the seam of the faceplate.
  • You should hear popping or snapping noises as the faceplate is being removed.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
The faceplate is attached by wires, so do not pull the faceplate very far away from the phone. The faceplate is attached by wires, so do not pull the faceplate very far away from the phone.
  • The faceplate is attached by wires, so do not pull the faceplate very far away from the phone.
Agregar Comentario
The faceplate is still attached through speakers that travel from the ear-piece to the motherboard. Carefully wedge the flat or pointed end of the spudger beneath the ear-piece and the faceplate. This may require a bit of force, as the ear-piece is stuck to the faceplate with adhesive.
  • The faceplate is still attached through speakers that travel from the ear-piece to the motherboard.
  • Carefully wedge the flat or pointed end of the spudger beneath the ear-piece and the faceplate.
  • This may require a bit of force, as the ear-piece is stuck to the faceplate with adhesive.
Agregar Comentario
The faceplate and keypad can now be completely removed from the phone.
  • The faceplate and keypad can now be completely removed from the phone.
Agregar Comentario
Wedge the spudger into the small gap between the phone and the metal casing of the motherboard. Slide the spudger underneath the metal and along the edge. The motherboard should begin to rise. There is a ribbon at the end of this groove, do not slide the spudger into the ribbon.
  • Wedge the spudger into the small gap between the phone and the metal casing of the motherboard.
  • Slide the spudger underneath the metal and along the edge. The motherboard should begin to rise.
    • There is a ribbon at the end of this groove, do not slide the spudger into the ribbon.
  • Now use the spudger to lift the other side of the motherboard.
Agregar Comentario
Lift the motherboard at an angle.
  • Lift the motherboard at an angle.
    • Do not completely remove the motherboard. Doing so will tear the ribbon!
Agregar Comentario
Gently pull the LCD screen upwards. It can be tricky do this, you may want to use a spudger to pry it up if it doesn't pull up easily.
  • Gently pull the LCD screen upwards.
    • It can be tricky do this, you may want to use a spudger to pry it up if it doesn't pull up easily.
  • This step requires soldering. Only do this step if you are OK with soldering small wires.
Agregar Comentario
Linea de Meta
Una persona más ha completado esta guía.
Aaron Rowley
Miembro Desde 21/01/10
33 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 16-32, Maness Winter 2010 Miembro de Cal Poly, Team 16-32, Maness Winter 2010
CPSU-MANESS-W10S16G32
4 Miembros
4 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 2,154
