Saltar al contenido principal
LG VX8700 Motherboard Replacement
Qué necesitas
  1. LG VX8700 Motherboard Replacement, Battery: paso 1, imagen 1 de 2 LG VX8700 Motherboard Replacement, Battery: paso 1, imagen 2 de 2
    • Make sure the phone is completely off.
    • Remove the back cover by sliding the tab away from the phone using one finger.
  2. LG VX8700 Motherboard Replacement: paso 2, imagen 1 de 2 LG VX8700 Motherboard Replacement: paso 2, imagen 2 de 2
    • Lift one side of the battery using a plastic opening tool or your fingers.
    • Carefully remove the battery and set it aside.
    • When installing the new battery, make sure to align the metal pins with those of the phone.
  3. LG VX8700 Motherboard Replacement, Keypad: paso 3, imagen 1 de 2 LG VX8700 Motherboard Replacement, Keypad: paso 3, imagen 2 de 2
    • Remove the nine 4 mm screws from the back cover with a Phillips #0 screwdriver.
  4. LG VX8700 Motherboard Replacement: paso 4, imagen 1 de 2 LG VX8700 Motherboard Replacement: paso 4, imagen 2 de 2
    • Insert the tip of the iFixit opening tool into the small notch on the side of the case.
    • Slide the opening tool along the seam and around the edge of the phone to separate the case.
  5. LG VX8700 Motherboard Replacement: paso 5, imagen 1 de 1
    • Separate the two halves of the phone.
    • The back of the phone, which houses the motherboard and keypad, is displayed on the left.
    • The plastic casing is displayed on the right.
  6. LG VX8700 Motherboard Replacement: paso 6, imagen 1 de 3 LG VX8700 Motherboard Replacement: paso 6, imagen 2 de 3 LG VX8700 Motherboard Replacement: paso 6, imagen 3 de 3
    • Hold the phone casing with one hand and the keypad assembly with the other.
    • Separate the phone casing from the keypad/motherboard.
  7. LG VX8700 Motherboard Replacement: paso 7, imagen 1 de 2 LG VX8700 Motherboard Replacement: paso 7, imagen 2 de 2
    • Pull the two boards apart to separate the keypad from the motherboard.
  8. LG VX8700 Motherboard Replacement, Motherboard: paso 8, imagen 1 de 1
    • First, pull back the tape covering the connection between the motherboard and the ribbon cable.
    • Separate the connection, using the plastic opening tool.
  9. LG VX8700 Motherboard Replacement: paso 9, imagen 1 de 2 LG VX8700 Motherboard Replacement: paso 9, imagen 2 de 2
    • After the connection is removed, the motherboard is successfully removed.
Conclusión
Equipo
Cal Poly, Team 8-16, Maness Winter 2012 Miembro de Cal Poly, Team 8-16, Maness Winter 2012
CPSU-MANESS-W12S8G16
4 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 14
Todo El Tiempo: 1,311
