Turn the phone off. Remove the back cover by sliding the tab away from the phone using one finger.
  • Turn the phone off.
  • Remove the back cover by sliding the tab away from the phone using one finger.
Agregar Comentario
Lift one side of the battery using a plastic opening tool or your fingers.
  • Lift one side of the battery using a plastic opening tool or your fingers.
  • Carefully remove the battery and set it aside.
Agregar Comentario
When installing the battery, make sure to align the metal pins with those of the phone.
  • When installing the battery, make sure to align the metal pins with those of the phone.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Turn your phone around and open the flip phone.
  • Turn your phone around and open the flip phone.
  • Locate the two grey rubber plugs on the LCD portion of the phone. These plugs cover up two screws.
  • Remove the two grey screw-covers at the bottom of the screen
Agregar Comentario
Remove the screen by using the tab to eject the screen. There is a gap between the case and the screen near the ear piece
  • Remove the screen by using the tab to eject the screen.
    • There is a gap between the case and the screen near the ear piece
    • Insert the plastic opening tool in the gap and pry the screen up.
  • The plastic screen cover is glued onto the phone, do not be alarmed if it may be difficult to pry it off.
Agregar Comentario
Unscrew the four corner 3.21mm screws to separate the the top cover of the phone
  • Unscrew the four corner 3.21mm screws to separate the the top cover of the phone
Agregar Comentario
Turn your phone around Remove the top cover of the phone by inserting the plastic opening tool into the groove.
  • Remove the top cover of the phone by inserting the plastic opening tool into the groove.
  • Carefully open the cover.
Agregar Comentario
Desolder the top ear piece using a soldering iron to remove the component
  • Desolder the top ear piece using a soldering iron to remove the component
  • The ear piece is the black component that is located at the top with black and red wires
Agregar Comentario
Remove the ear piece from the phone by lifting it using a plastic opening tool. Remove the ear piece from the phone by lifting it using a plastic opening tool.
  • Remove the ear piece from the phone by lifting it using a plastic opening tool.
Agregar Comentario
Conclusión
Stanley Thomas
Miembro Desde 20/01/12
38 Reputación
8 Guías creadas
Equipo
Cal Poly, Team 8-16, Maness Winter 2012 Miembro de Cal Poly, Team 8-16, Maness Winter 2012
CPSU-MANESS-W12S8G16
4 Miembros
14 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 904
