Introducción
Steps to replace the LG VX8550 speaker
Slide the battery release up.
  • Slide the battery release up.
Agregar Comentario
Remove the battery by lifting away from the case.
  • Remove the battery by lifting away from the case.
Agregar Comentario
Remove the 2 screw covers next to the rear speaker with a Push Pin.
  • Remove the 2 screw covers next to the rear speaker with a Push Pin.
Agregar Comentario
Remove the 4 cover screws with a Philips #00 screwdriver.
  • Remove the 4 cover screws with a Philips #00 screwdriver.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Use the iPod opening tool to pry off the back casing.
  • Use the iPod opening tool to pry off the back casing.
Agregar Comentario
Continue sliding the iPod opening tool around the seam of the casing to separate the front and back casings.
  • Continue sliding the iPod opening tool around the seam of the casing to separate the front and back casings.
Agregar Comentario
Separate the casing halves.
  • Separate the casing halves.
  • Be sure to keep track of the side buttons as they fall out.
Agregar Comentario
With the back casing removed the speaker is visible.
  • With the back casing removed the speaker is visible.
Agregar Comentario
Lift up under top end of circuit board with the Spludger to access retaining clip.
  • Lift up under top end of circuit board with the Spludger to access retaining clip.
Agregar Comentario
Carefully pry up on retaining clip with the Spudger to release the speaker.
  • Carefully pry up on retaining clip with the Spudger to release the speaker.
Agregar Comentario
Carefully unplug speaker connector from circuit board with your fingers.
  • Carefully unplug speaker connector from circuit board with your fingers.
Agregar Comentario
Remove the speaker by lifting up.
  • Remove the speaker by lifting up.
Agregar Comentario
Conclusión
Nathan Jones
Miembro Desde 10/04/10
83 Reputación
20 Guías creadas
Equipo
Cal Poly, Team 34-55, Forte Spring 2010 Miembro de Cal Poly, Team 34-55, Forte Spring 2010
CPSU-FORTE-S10S34G55
5 Miembros
20 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 1,909
