Introducción
Steps to remove the LG VX8550 scroll wheel
Slide the battery release up.
  • Slide the battery release up.
Agregar Comentario
Remove the battery by lifting away from the case.
  • Remove the battery by lifting away from the case.
Agregar Comentario
Remove the 2 screw covers next to the rear speaker with a Push Pin.
  • Remove the 2 screw covers next to the rear speaker with a Push Pin.
Agregar Comentario
Remove the 4 cover screws with a Philips #00 screwdriver.
  • Remove the 4 cover screws with a Philips #00 screwdriver.
Agregar Comentario
Use the iPod opening tool to pry off the back casing.
  • Use the iPod opening tool to pry off the back casing.
Agregar Comentario
Continue sliding the iPod opening tool around the seam of the casing to separate the front and back casings.
  • Continue sliding the iPod opening tool around the seam of the casing to separate the front and back casings.
Agregar Comentario
Separate the casing halves.
  • Separate the casing halves.
  • Be sure to keep track of the side buttons as they fall out.
Agregar Comentario
Remove the 2 screws from the back of the phone with a Phillips #00 Screwdriver.
  • Remove the 2 screws from the back of the phone with a Phillips #00 Screwdriver.
Agregar Comentario
Carefully lift up on the motherboard to see the ribbon cables underneath.
  • Carefully lift up on the motherboard to see the ribbon cables underneath.
  • Use the spudger to carefully disconnect the ribbon cable from the motherboard.
Agregar Comentario
Remove the motherboard from the front casing by lifting straight up.
  • Remove the motherboard from the front casing by lifting straight up.
Agregar Comentario
Lay the phone with the screen facedown.
  • Lay the phone with the screen facedown.
  • The 6 slider screws are visible.
Agregar Comentario
Peel back but don't remove the blue tape to access the 2 center screws.
  • Peel back but don't remove the blue tape to access the 2 center screws.
  • Remove the 6 slider screws with the Phillips #00 screwdriver.
Agregar Comentario
Lift the keypad housing away from the slider.
  • Lift the keypad housing away from the slider.
Agregar Comentario
Remove the 2 screw covers next to the speaker with a push pin next to the camera.
  • Remove the 2 screw covers next to the speaker with a push pin next to the camera.
Agregar Comentario
Remove the 6 screws with a Phillips #00 Screwdriver.
  • Remove the 6 screws with a Phillips #00 Screwdriver.
Agregar Comentario
Use the ipod opening tool to pry the screen casing and the slider mechanism apart from each other.
  • Use the ipod opening tool to pry the screen casing and the slider mechanism apart from each other.
Agregar Comentario
Carefully lift the slider mechanism to see the ribbon cables underneath.
  • Carefully lift the slider mechanism to see the ribbon cables underneath.
Agregar Comentario
Slide ribbon cable through the slider mechanism.
  • Slide ribbon cable through the slider mechanism.
Agregar Comentario
Separate the two halves.
  • Separate the two halves.
Agregar Comentario
With the spudger, lift up under the connector to unplug it from the circuit board.
  • With the spudger, lift up under the connector to unplug it from the circuit board.
Agregar Comentario
Lift and remove the blue tape from screen connector.
  • Lift and remove the blue tape from screen connector.
Agregar Comentario
Lift the top edge of the screen using a pin to pry under the corner.
  • Lift the top edge of the screen using a pin to pry under the corner.
Agregar Comentario
Grasp the ribbon cable near the connector and carefully slide it out of the white connector.
  • Grasp the ribbon cable near the connector and carefully slide it out of the white connector.
  • It is helpful to gently wiggle the ribbon cable from side to side.
Agregar Comentario
Carefully lift the circuit board away from the screen casing using Ipod Opening Tool. Peel the circuit board away from the adhesive backing with your finger.
  • Carefully lift the circuit board away from the screen casing using Ipod Opening Tool.
  • Peel the circuit board away from the adhesive backing with your finger.
Agregar Comentario
Remove the scroll wheel from the casing with your hands.
  • Remove the scroll wheel from the casing with your hands.
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Nathan Jones
Miembro Desde 10/04/10
83 Reputación
20 Guías creadas
Equipo
Cal Poly, Team 34-55, Forte Spring 2010 Miembro de Cal Poly, Team 34-55, Forte Spring 2010
CPSU-FORTE-S10S34G55
5 Miembros
20 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 2
Todo El Tiempo: 2,249
