Saltar al contenido principal
LG VX7000 Internal LCD Screen Replacement
Qué necesitas
  1. LG VX7000 Internal LCD Screen Replacement, Internal LCD Screen: paso 1, imagen 1 de 1
    • Using Tweezers, remove 4 rubber screw covers.
    • Remove screws located under rubber plugs using the screwdriver by turning counterclockwise.
    • NOTE: Screws will not come completely out of phone.
  2. LG VX7000 Internal LCD Screen Replacement: paso 2, imagen 1 de 1
    • Using the iPod Opening Tool, pry the face plate off the front of the phone.
    • NOTE: There will be a significant amount of resistance to removing the face plate from the phone.
  3. LG VX7000 Internal LCD Screen Replacement: paso 3, imagen 1 de 1
    • Unsnap gold plate from the secondary logic board.
    • Reposition the plate so that it is out of the way for face plate removal.
  4. LG VX7000 Internal LCD Screen Replacement: paso 4, imagen 1 de 1
    • Twist upper half of face plate in order to release it from the hinge.
    • Using tweezers detach the speaker and the secondary battery from the faceplate, leaving wires attached.
  5. LG VX7000 Internal LCD Screen Replacement: paso 5, imagen 1 de 1
    • Align new face plate in correct orientation in order to install.
Conclusión
Nichole Shaw
Miembro Desde 04/13/10
1 Reputación
7 Guías creadas
Equipo
Cal Poly, Team 18-75, Johann Spring 2010 Miembro de Cal Poly, Team 18-75, Johann Spring 2010
CPSU-JOHANN-S10S18G75
4 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 2,219
