Saltar al contenido principal
LG VX6100 Front Case Replacement
Qué necesitas
  1. LG VX6100 Front Case Replacement, Front Case: paso 1, imagen 1 de 1
    • Remove the four grey plugs using either tweezers or a push pin.
  2. LG VX6100 Front Case Replacement: paso 2, imagen 1 de 1
    • Remove the four screws that are now exposed using a Phillips #00 screwdriver.
    • Be sure to put the screws in a safe place as they are very small and easy to lose.
  3. LG VX6100 Front Case Replacement: paso 3, imagen 1 de 1
    • Once all the screws have been removed, use a plastic opener tool to pry the case from the rest of the phone.
    • Insert the opener tool into the seem between the case and the phone. Apply pressure to separate the two pieces.
    • Do this across the entire length of the seem until the case is no longer attached to the phone.
  4. LG VX6100 Front Case Replacement: paso 4, imagen 1 de 1
    • The case can now be removed and the interior of the front is accessible.
Conclusión
Ryan Bishop
Miembro Desde 04/17/12
1 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 12-39, Regan Spring 2012 Miembro de Cal Poly, Team 12-39, Regan Spring 2012
CPSU-REGAN-S12S12G39
3 Miembros
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 5
Todo El Tiempo: 764
