Introducción
This guide is for dismantling the body of the LG VX6000, a step that is required for many other repairs
Partes
No se requieren partes.
Locate the dark gray tab on the back of the phone towards the top.
  • Locate the dark gray tab on the back of the phone towards the top.
  • Push the tab towards the top of the phone to release the battery.
Remove battery
Ryan Brekke - Contestar
Remove the battery by lifting up and rotating the battery away from the bottom edge.
  • Remove the battery by lifting up and rotating the battery away from the bottom edge.
Agregar Comentario
Set the battery aside in a safe location.
  • Set the battery aside in a safe location.
Agregar Comentario
Pull out the two rubber cushions located on the top of the phone using tweezers.
  • Pull out the two rubber cushions located on the top of the phone using tweezers.
  • Only remove the two cushions that are circled!
Agregar Comentario
Unscrew the six screws seen on the back using a Phillips 00 Screwdriver.
  • Unscrew the six screws seen on the back using a Phillips 00 Screwdriver.
  • Remove screws and carefully place on a uncluttered surface or in a small container.
  • The screws are small and easily lost.
Agregar Comentario
Remove the back of the phone using your hands.
  • Remove the back of the phone using your hands.
  • There is a pair of red and blue wires that plugs into the motherboard. These wires will snap if you force the pieces apart.
  • Remove the back of the phone very gently. Use your fingernail or tweezers to unplug the wires.
  • To reattach the back, you must plug these wires back in.
Agregar Comentario
Linea de Meta
Equipo
Cal Poly, Team 4-11, Forte Winter 2010 Miembro de Cal Poly, Team 4-11, Forte Winter 2010
CPSU-FORTE-W10S4G11
5 Miembros
10 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 2,011
