Introducción
A guide on how to replace the logic board in the LG VX5400.
Partes
No se requieren partes.
Turn off the cell phone and turn it over on its back side
  • Turn off the cell phone and turn it over on its back side
Agregar Comentario
Hold the phone case in your palm and slide the back cover towards yourself using your thumb
  • Hold the phone case in your palm and slide the back cover towards yourself using your thumb
Agregar Comentario
Slide a tool or finger into the notch at the top of the battery  to carefully remove it. Slide a tool or finger into the notch at the top of the battery  to carefully remove it. Slide a tool or finger into the notch at the top of the battery  to carefully remove it.
  • Slide a tool or finger into the notch at the top of the battery to carefully remove it.
Agregar Comentario
Guía de regalos para el día del padre
Honremos a más que nuestros padres—celebremos a todos los mentores que nos enseñaron a reparar.
Honremos a aquellos que nos enseñaron a reparar.
Take the Philips screwdriver and unscrew the four visible screws on the backside of the phone indicated by the four red circles.
  • Take the Philips screwdriver and unscrew the four visible screws on the backside of the phone indicated by the four red circles.
Agregar Comentario
Then, take the pointed end of a spudger and pry out the rubber stopper to reveal the last screw at the top indicated with the blue circle.
  • Then, take the pointed end of a spudger and pry out the rubber stopper to reveal the last screw at the top indicated with the blue circle.
Agregar Comentario
While the phone is open and faced up, carefully insert a tool into the middle to seperate the bottom half of the phone. While the phone is open and faced up, carefully insert a tool into the middle to seperate the bottom half of the phone.
  • While the phone is open and faced up, carefully insert a tool into the middle to seperate the bottom half of the phone.
Agregar Comentario
Carefully slide out the keypad and remove the logic board. Then insert new the logic board. Carefully slide out the keypad and remove the logic board. Then insert new the logic board.
  • Carefully slide out the keypad and remove the logic board. Then insert new the logic board.
Agregar Comentario
Conclusión
2 personas más completaron esta guía.
Sourabh
Miembro Desde 15/04/10
132 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 26-26, Regan Spring 2010 Miembro de Cal Poly, Team 26-26, Regan Spring 2010
CPSU-REGAN-S10S26G26
4 Miembros
10 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 5
Todo El Tiempo: 2,267
