Saltar al contenido principal
LG VX5400 Keypad Replacement
Qué necesitas
  1. LG VX5400 Keypad Replacement, Battery: paso 1, imagen 1 de 1
    • Turn off the cell phone and turn it over on its back side
  2. LG VX5400 Keypad Replacement: paso 2, imagen 1 de 1
    • Hold the phone case in your palm and slide the back cover towards yourself using your thumb
  3. LG VX5400 Keypad Replacement: paso 3, imagen 1 de 3 LG VX5400 Keypad Replacement: paso 3, imagen 2 de 3 LG VX5400 Keypad Replacement: paso 3, imagen 3 de 3
    • Slide a tool or finger into the notch at the top of the battery to carefully remove it.
  4. LG VX5400 Keypad Replacement, Keypad: paso 4, imagen 1 de 1
    • Remove the rubber stopper from the back top of the phone with the pointed end of a spudger.
  5. LG VX5400 Keypad Replacement: paso 5, imagen 1 de 1
    • Use the Phillip screw driver to remove the hidden screw, which is marked by the red square
  6. LG VX5400 Keypad Replacement: paso 6, imagen 1 de 1
    • Gently split open the front and back of the bottom casing of the phone with fingers.
  7. LG VX5400 Keypad Replacement: paso 7, imagen 1 de 1
    • Carefully pull the key pad from the phone through the opening.
  8. LG VX5400 Keypad Replacement: paso 8, imagen 1 de 1
    • See here for parts that have been removed.
Conclusión
Equipo
Cal Poly, Team 26-26, Regan Spring 2010 Miembro de Cal Poly, Team 26-26, Regan Spring 2010
CPSU-REGAN-S10S26G26
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 9
Ultimos 30 días: 14
Todo El Tiempo: 2,333
