Introducción
This guide illustrates how to replace the LG VX5300 keypad.
Partes
No se requieren partes.
Carefully slide battery cover off in a downward direction. Using the plastic opening tool, remove the battery. Light force may be necessary. Using the plastic opening tool, remove the battery. Light force may be necessary.
  • Carefully slide battery cover off in a downward direction.
  • Using the plastic opening tool, remove the battery. Light force may be necessary.
Agregar Comentario
Using a Phillips #0 screwdriver, remove the five screws from the back cover and carefully set them aside.
  • Using a Phillips #0 screwdriver, remove the five screws from the back cover and carefully set them aside.
Agregar Comentario
Using the plastic opening tool, carefully lift the back cover off.
  • Using the plastic opening tool, carefully lift the back cover off.
Agregar Comentario
Before touching anything inside the phone: it is crucial that you are very cautious when working around the wiring and sensor bars. Look to the following photo for the location of the two sensor bars.
  • Before touching anything inside the phone: it is crucial that you are very cautious when working around the wiring and sensor bars.
  • Look to the following photo for the location of the two sensor bars.
  • Without disconnecting the orange wire, carefully flip the computer chip over and lay flat on the table, exposing the keypad.
Agregar Comentario
Carefully remove the keypad and replace with the new keypad. If sensor bars behind the volume and camera buttons fall out, gently put them back in place behind the buttons.
  • Carefully remove the keypad and replace with the new keypad.
  • If sensor bars behind the volume and camera buttons fall out, gently put them back in place behind the buttons.
Agregar Comentario
Carefully set the computer chip back in place.
  • Carefully set the computer chip back in place.
Agregar Comentario
Place the back cover back on and secure it with the screws. Place the back cover back on and secure it with the screws.
  • Place the back cover back on and secure it with the screws.
Agregar Comentario
Insert the battery. Slide the back cover on the phone.
  • Insert the battery.
  • Slide the back cover on the phone.
Agregar Comentario
Linea de Meta
Ashley
Miembro Desde 12/02/13
9 Reputación
3 Guías creadas
Equipo
Ohio State, Team 1-1, Buehl Spring 2013 Miembro de Ohio State, Team 1-1, Buehl Spring 2013
OSU-BUEHL-S13S1G1
3 Miembros
4 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 422
