Saltar al contenido principal
LG VX5200 Face Plate Replacement
Qué necesitas
  1. LG VX5200 Face Plate Replacement, Battery: paso 1, imagen 1 de 2 LG VX5200 Face Plate Replacement, Battery: paso 1, imagen 2 de 2
    • Turn the phone on its back.
  2. LG VX5200 Face Plate Replacement: paso 2, imagen 1 de 2 LG VX5200 Face Plate Replacement: paso 2, imagen 2 de 2
    • Orient the phone as shown.
    • Remove the battery cover by pushing upward with your thumb.
  3. LG VX5200 Face Plate Replacement: paso 3, imagen 1 de 2 LG VX5200 Face Plate Replacement: paso 3, imagen 2 de 2
    • Place your fingernail at the top of the battery and pry the battery out towards you.
  4. LG VX5200 Face Plate Replacement, Face Plate: paso 4, imagen 1 de 3 LG VX5200 Face Plate Replacement, Face Plate: paso 4, imagen 2 de 3 LG VX5200 Face Plate Replacement, Face Plate: paso 4, imagen 3 de 3
    • Flip the phone open.
    • Remove the four rubber plugs, located at the corners of the LCD screen, with a push-pin.
    • Use a Phillips #00 screwdriver to remove the four screws located underneath the rubber plugs.
  5. LG VX5200 Face Plate Replacement: paso 5, imagen 1 de 3 LG VX5200 Face Plate Replacement: paso 5, imagen 2 de 3 LG VX5200 Face Plate Replacement: paso 5, imagen 3 de 3
    • Insert the opening tool in the seam of the top portion of the flip phone.
    • Gently pry the seam open.
    • Move the opening tool around the perimeter of the seam and gently take the front LCD face plate out.
  6. LG VX5200 Face Plate Replacement: paso 6, imagen 1 de 3 LG VX5200 Face Plate Replacement: paso 6, imagen 2 de 3 LG VX5200 Face Plate Replacement: paso 6, imagen 3 de 3
    • Close the flip phone.
    • Hold the base of the phone and gently remove the faceplate.
    • Place the phone and the faceplate on a clean, flat surface.
Conclusión
Una persona más ha completado esta guía.
Equipo
Cal Poly, Team 4-13, Forte Winter 2010 Miembro de Cal Poly, Team 4-13, Forte Winter 2010
CPSU-FORTE-W10S4G13
5 Miembros
15 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 2,006
