Introducción
Replacing the LCD screen.
Turn the closed phone so that the back panel is facing you.
  • Turn the closed phone so that the back panel is facing you.
  • Press down and forward firmly on the gray tab in the middle of the phone.
Agregar Comentario
Now just lift up on the battery and remove it from the phone. Now just lift up on the battery and remove it from the phone.
  • Now just lift up on the battery and remove it from the phone.
Agregar Comentario
Remove 4 rubber grommets using the Spudger.
  • Remove 4 rubber grommets using the Spudger.
Agregar Comentario
Remove 4 screws using the Phillips #00 Screwdriver.
  • Remove 4 screws using the Phillips #00 Screwdriver.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Carefully pry off outer cover using iPod Opening Tool. Carefully pry off outer cover using iPod Opening Tool. Carefully pry off outer cover using iPod Opening Tool.
  • Carefully pry off outer cover using iPod Opening Tool.
Agregar Comentario
Remove speaker using the Spudger. Remove speaker using the Spudger.
  • Remove speaker using the Spudger.
Agregar Comentario
Remove vibrator using the Spudger. Remove vibrator using the Spudger.
  • Remove vibrator using the Spudger.
Agregar Comentario
Lift up LCD display using iPod Opening Tool. Lift up LCD display using iPod Opening Tool.
  • Lift up LCD display using iPod Opening Tool.
Agregar Comentario
DO NOT TOUCH THE SOLDERING IRON. IT IS EXTREMELY HOT!
  • DO NOT TOUCH THE SOLDERING IRON. IT IS EXTREMELY HOT!
  • De-solder solder joint using Soldering Iron.
Agregar Comentario
Pry off ribbon cable using iPod Opening Tool. Pry off ribbon cable using iPod Opening Tool.
  • Pry off ribbon cable using iPod Opening Tool.
Agregar Comentario
Conclusión
David Foster
Miembro Desde 11/04/10
1 Reputación
16 Guías creadas
Equipo
Cal Poly, Team 25-88, Amido Spring 2010 Miembro de Cal Poly, Team 25-88, Amido Spring 2010
CPSU-AMIDO-S10S25G88
4 Miembros
18 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 2,200
