Introducción
BEFORE STARTING, note that this repair guide requires soldering experience!
Turn off the cellphone by pressing down on the red "END" button for 3 seconds. Flip cellphone over and press up on the gray sliding mechanism towards the top of the phone. At the same time, pull on the large silver battery and it should come right off.
  • Turn off the cellphone by pressing down on the red "END" button for 3 seconds.
  • Flip cellphone over and press up on the gray sliding mechanism towards the top of the phone. At the same time, pull on the large silver battery and it should come right off.
Agregar Comentario
Use the T7 Torx screwdriver to remove the four screws that are in the cavity where the battery was.
  • Use the T7 Torx screwdriver to remove the four screws that are in the cavity where the battery was.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Carefully wedge the spudger around the sides of the plastic casing and pry off the back side of the phone. Be careful when prying off the case. The spudger can damage the phone case. Be careful when prying off the case. The spudger can damage the phone case.
  • Carefully wedge the spudger around the sides of the plastic casing and pry off the back side of the phone.
  • Be careful when prying off the case. The spudger can damage the phone case.
Agregar Comentario
Gently pry off the logic board with the spudger; notice the gold strip that connects the logic board to the rest of the phone. Prying the logic board off too quickly may damage the strip. Desolder the part of the gold strip that is attached to the logic board.
  • Gently pry off the logic board with the spudger; notice the gold strip that connects the logic board to the rest of the phone.
  • Prying the logic board off too quickly may damage the strip.
  • Desolder the part of the gold strip that is attached to the logic board.
  • Use the spudger to carefully lift up the small latch that holds the gold strip onto the logic board.
Agregar Comentario
Conclusión
Mark Cabaj
Miembro Desde 30/03/10
1 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 34-58, Forte Spring 2010 Miembro de Cal Poly, Team 34-58, Forte Spring 2010
CPSU-FORTE-S10S34G58
5 Miembros
9 Guías creadas
It seems you have snapped off the female connector door (As I have following your guide; this is the black piece with pins attached to the bottom of the gold strip) from the logic board... I was told that the device is broken in this state, since the strip was to be released from the connector, but am wondering if the door can just be soldered back onto the logic board and still be functioning?
Peter Pann - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 2,442
