Saltar al contenido principal
LG Tribute Front Facing Camera Replacement
Qué necesitas
  1. LG Tribute Front Facing Camera  Replacement, Battery: paso 1, imagen 1 de 2 LG Tribute Front Facing Camera  Replacement, Battery: paso 1, imagen 2 de 2
    • Use the plastic opening tool to pry off the back cover.
  2. LG Tribute Front Facing Camera  Replacement: paso 2, imagen 1 de 1
    • Lift the battery out of place.
    • When replacing the battery, the (+) and (-) symbols must match up with the phone's charging nodes.
  3. LG Tribute Front Facing Camera  Replacement, Mid-panel: paso 3, imagen 1 de 2 LG Tribute Front Facing Camera  Replacement, Mid-panel: paso 3, imagen 2 de 2
    • Remove eight 4mm screws using a Phillips head 000 screwdriver (PH000).
  4. LG Tribute Front Facing Camera  Replacement: paso 4, imagen 1 de 2 LG Tribute Front Facing Camera  Replacement: paso 4, imagen 2 de 2
    • Use a plastic opening tool to loosen the tabs around the edge of the phone.
    • Inserting a thin piece of plastic will help prevent opened tabs from locking back into place.
    • This step can be frustrating, but requires patience. Avoid the temptation to pry the panel loose. Using excessive force may break the delicate tabs.
  5. LG Tribute Front Facing Camera  Replacement, Front Facing Camera: paso 5, imagen 1 de 2 LG Tribute Front Facing Camera  Replacement, Front Facing Camera: paso 5, imagen 2 de 2
    • Use the plastic opening tool to carefully pry the front-facing camera from the motherboard.
Conclusión
4 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 1,087
