Saltar al contenido principal
LG Neon II Battery Replacement
Qué necesitas
  1. LG Neon II Battery Replacement, Battery: paso 1, imagen 1 de 1
    • To gain access to the phone’s speaker, grip the phone firmly in an inverted position with the back of the unit facing up and the LG insignia positioned away from you.
    • Using both hands as support, use your thumbs to gently guide the rear housing away and in the direction of the arrow.
  2. LG Neon II Battery Replacement: paso 2, imagen 1 de 1
    • After removing the phone’s back-panel, securely cushion the front of the phone on a soft surface such as a cloth or your hand.
    • Gently insert a spudger under the lip of the battery, preferably the lip away from the camera eye.
    • Gently pry the battery out of its seated position.
Conclusión
2 personas más completaron esta guía.
Sara
Miembro Desde 09/18/12
65 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 1-6, Propen Fall 2012 Miembro de Cal Poly, Team 1-6, Propen Fall 2012
CPSU-PROPEN-F12S1G6
3 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 10
Ultimos 30 días: 11
Todo El Tiempo: 910
