Introducción
This guide will assist you in replacing your phone's faulty camera.
Partes
No se requieren partes.
Use a spudger to remove the two screw covers below display. Use a screw driver to remove the four Phillips #00 (3.3mm) screws at corners of the display.
  • Use a spudger to remove the two screw covers below display.
  • Use a screw driver to remove the four Phillips #00 (3.3mm) screws at corners of the display.
Agregar Comentario
Caution: Wires and ribbon connect the front case to the main body. Exhibit care when separating front case from the main body as to not break the connections. Note: Side buttons may fall out when removing the front case. Do not misplace them. Note: Each side button will only fit in the side that it came from.
  • Caution: Wires and ribbon connect the front case to the main body. Exhibit care when separating front case from the main body as to not break the connections.
  • Note: Side buttons may fall out when removing the front case. Do not misplace them.
  • Note: Each side button will only fit in the side that it came from.
  • Insert a spudger between the black and grey casings and gently spread them apart.
  • Work around the device gradually, opening the gap further.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Caution: The wires and ribbon connector can break easily. Exhibit care when removing them. Use the spudger and lift upward to disconnect the ribbon from the main part of the phone. Carefully remove any parts stuck to the front case such as speakers.
  • Caution: The wires and ribbon connector can break easily. Exhibit care when removing them.
  • Use the spudger and lift upward to disconnect the ribbon from the main part of the phone.
  • Carefully remove any parts stuck to the front case such as speakers.
Agregar Comentario
Disconnect the ribbons on both sides of the camera by prying them up with a spudger. Disconnect the ribbons on both sides of the camera by prying them up with a spudger. Disconnect the ribbons on both sides of the camera by prying them up with a spudger.
  • Disconnect the ribbons on both sides of the camera by prying them up with a spudger.
Agregar Comentario
Hold the wiring out of the way and pull up with a spudger behind the camera. The camera unit should come unglued and separate from the phone.
  • Hold the wiring out of the way and pull up with a spudger behind the camera.
  • The camera unit should come unglued and separate from the phone.
Agregar Comentario
Conclusión
Braden Burk
Miembro Desde 22/01/12
1 Reputación
10 Guías creadas
Equipo
Cal Poly, Team 3-29, Amido Winter 2012 Miembro de Cal Poly, Team 3-29, Amido Winter 2012
CPSU-AMIDO-W12S3G29
4 Miembros
14 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 637
