Introducción
This guide will help you replace the front casing on the phone.
Partes
No se requieren partes.
Place the phone on a flat surface that the back is facing you. Remove the back panel by placing your thumb on the LG logo and sliding the panel across the length of the phone until it is removed.
  • Place the phone on a flat surface that the back is facing you. Remove the back panel by placing your thumb on the LG logo and sliding the panel across the length of the phone until it is removed.
Agregar Comentario
Once the panel is removed, you are looking directly at the battery. It is the black rectangle in the middle of the phone.  You can remove the battery by sliding a finger into the notch where the LG logo was on the panel and lifting up the battery.
  • Once the panel is removed, you are looking directly at the battery. It is the black rectangle in the middle of the phone. You can remove the battery by sliding a finger into the notch where the LG logo was on the panel and lifting up the battery.
Agregar Comentario
Remove the battery completely from the phone.
  • Remove the battery completely from the phone.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Before continuing pull off all the rubber tabs to the headphones, and the power input.
  • Before continuing pull off all the rubber tabs to the headphones, and the power input.
Agregar Comentario
Now turn the phone so that you can see the back where the battery was. Using a screw driver, unscrew the 6 screws holding the back casing together.
  • Now turn the phone so that you can see the back where the battery was. Using a screw driver, unscrew the 6 screws holding the back casing together.
Agregar Comentario
At the top of the logic board there is a small rectangle with a white pad on it, use your tweezers and gently grip the neck of the orange wire.
  • At the top of the logic board there is a small rectangle with a white pad on it, use your tweezers and gently grip the neck of the orange wire.
  • Gently pull up on the orange wire until it comes loose. It may take some force so do not be concerned with being overly gentle.
Agregar Comentario
Open your phone to find four small rubber pads at each corner of the screen.
  • Open your phone to find four small rubber pads at each corner of the screen.
  • Remove each rubber piece and unscrew the screw under the rubber piece. You can see what the screw looks like under the rubber piece in the top right screw.
Agregar Comentario
Use a splurger to slide in between the phone and the cover.
  • Use a splurger to slide in between the phone and the cover.
Agregar Comentario
The cover will be separated from the phone and may be removed.
  • The cover will be separated from the phone and may be removed.
Agregar Comentario
Conclusión
Kris Oznowic
Miembro Desde 13/01/10
1 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 11-2, Forte Winter 2010 Miembro de Cal Poly, Team 11-2, Forte Winter 2010
CPSU-FORTE-W10S11G2
5 Miembros
10 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 1,860
