Saltar al contenido principal
LG LX150 Internal Back Cover Replacement
Qué necesitas
  1. LG LX150 Internal Back Cover Replacement, Back Cover: paso 1, imagen 1 de 3 LG LX150 Internal Back Cover Replacement, Back Cover: paso 1, imagen 2 de 3 LG LX150 Internal Back Cover Replacement, Back Cover: paso 1, imagen 3 de 3
    • First locate the button and the bottom of the cover where the arrow is. Press down on the button.
    • While pushing down on the button, slide the cover up towards the hinge until the cover comes off.
    • The battery will be visible after removing the back cover.
  2. LG LX150 Internal Back Cover Replacement, Battery: paso 2, imagen 1 de 2 LG LX150 Internal Back Cover Replacement, Battery: paso 2, imagen 2 de 2
    • Simultaneously push the battery forward and pull up from the bottom.
  3. LG LX150 Internal Back Cover Replacement: paso 3, imagen 1 de 1
    • Once the battery is loose it can be easily removed. The phone's ID tag will be visible once the battery is removed.
    • Be careful of damaged or leaking batteries. If your battery appears damaged, remove it with care and find a replacement.
  4. LG LX150 Internal Back Cover Replacement, Internal Back Cover: paso 4, imagen 1 de 3 LG LX150 Internal Back Cover Replacement, Internal Back Cover: paso 4, imagen 2 de 3 LG LX150 Internal Back Cover Replacement, Internal Back Cover: paso 4, imagen 3 de 3
    • Remove the 7 phillips screws indicated by the red arrows using the phillips #0 screwdriver.
    • Insert the flat end of the spudger in-between the black and blue phone casing on the side of the phone and split the the blue and black apart. Work your way around the perimeter of the cover, loosening all corners.
  5. LG LX150 Internal Back Cover Replacement: paso 5, imagen 1 de 2 LG LX150 Internal Back Cover Replacement: paso 5, imagen 2 de 2
    • Remove the internal back cover after loosening all the corners.
    • The second picture below is what you will see after removing the internal back cover.
Conclusión
Una persona más ha completado esta guía.
Daniel Simpson
Miembro Desde 04/18/10
60 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 10-44, Garner Spring 2010 Miembro de Cal Poly, Team 10-44, Garner Spring 2010
CPSU-GARNER-S10S10G44
4 Miembros
18 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 1,662
