Introducción
Use this guide to remove the LG LX150's front cover.
Partes
No se requieren partes.
Use the spudger to pry out the indicated rubber squares. Use the #0 Phillips screwdriver to take out the revealed screws. Use the #0 Phillips screwdriver to take out the revealed screws.
  • Use the spudger to pry out the indicated rubber squares.
  • Use the #0 Phillips screwdriver to take out the revealed screws.
Agregar Comentario
Carefully lodge the spudger between the face plate and the hinge mechanism. Gently pry the face plate until it releases from place holders. Gently pry the face plate until it releases from place holders.
  • Carefully lodge the spudger between the face plate and the hinge mechanism.
  • Gently pry the face plate until it releases from place holders.
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Tye Barba
Miembro Desde 15/04/10
88 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 10-44, Garner Spring 2010 Miembro de Cal Poly, Team 10-44, Garner Spring 2010
CPSU-GARNER-S10S10G44
4 Miembros
18 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 2
Últimos 30 Días: 2
Todo El Tiempo: 1,780
