Introducción
This guide will help you replace the inner LCD screen if broken or in need of repair.
Make sure you remove the battery by lifting the tab on the back of the phone before opening the case.
  • Make sure you remove the battery by lifting the tab on the back of the phone before opening the case.
  • Flip open the phone and locate the four screw covers.
Agregar Comentario
Remove all four screw covers by using an IPod opening tool. They should come off relatively easy.
  • Remove all four screw covers by using an IPod opening tool. They should come off relatively easy.
Agregar Comentario
Using a T6 Torx screwdriver, remove all four screws.
  • Using a T6 Torx screwdriver, remove all four screws.
Agregar Comentario
Once the screws are removed, use an IPod opening tool to separate the front cover from the inner screen cover. Run the Ipod opening tool down both sides,disconnecting the tabs that hold the covers together. Run the Ipod opening tool down both sides,disconnecting the tabs that hold the covers together.
  • Once the screws are removed, use an IPod opening tool to separate the front cover from the inner screen cover.
  • Run the Ipod opening tool down both sides,disconnecting the tabs that hold the covers together.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Pull the inner screen cover towards you and up in order to separate it from the front cover. Pull the inner screen cover towards you and up in order to separate it from the front cover.
  • Pull the inner screen cover towards you and up in order to separate it from the front cover.
Agregar Comentario
Remove the tape from the bottom of the LCD screen.
  • Remove the tape from the bottom of the LCD screen.
Agregar Comentario
Carefully lift the LCD screen and peel it from the gold ribbon. The sticky connection runs all the way around the LCD screen. Carefully lift the LCD screen and peel it from the gold ribbon. The sticky connection runs all the way around the LCD screen. Carefully lift the LCD screen and peel it from the gold ribbon. The sticky connection runs all the way around the LCD screen.
  • Carefully lift the LCD screen and peel it from the gold ribbon. The sticky connection runs all the way around the LCD screen.
Agregar Comentario
Flip the screen over so that you can see the outer LCD screen and the circuit board. Insert spudger in the bottom right corner. Lift up and move the spudger across the bottom.
  • Flip the screen over so that you can see the outer LCD screen and the circuit board.
  • Insert spudger in the bottom right corner.
  • Lift up and move the spudger across the bottom.
  • The third photo is rotated 180 degrees.
Agregar Comentario
Use the pointy side of the spudger to peel off the interior tape. Flip the assembly over and peel the circuit board from the screen.
  • Use the pointy side of the spudger to peel off the interior tape.
  • Flip the assembly over and peel the circuit board from the screen.
Agregar Comentario
Use the spudger to remove the LCD screen from its backing. Use the spudger to remove the LCD screen from its backing.
  • Use the spudger to remove the LCD screen from its backing.
Agregar Comentario
Conclusión
Joshua Herrmann
Miembro Desde 16/04/10
8 Reputación
16 Guías creadas
Equipo
Cal Poly, Team 6-14, Maness Spring 2010 Miembro de Cal Poly, Team 6-14, Maness Spring 2010
CPSU-MANESS-S10S6G14
4 Miembros
16 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 2,155
