Introducción
We disassembled the LG Gram 15" to see how the Surface/MacBook competitor stacks up.
Reference shot with packaging.
  • Reference shot with packaging.
Agregar Comentario
Reference shots. Reference shots. Reference shots.
  • Reference shots.
Agregar Comentario
We first use tweezers to remove the three plastic screw covers and five rubber bumpers. We find eight Phillips screws holding the case together. After removing the screws, we use picks to remove the lower case which is held in with clips.
  • We first use tweezers to remove the three plastic screw covers and five rubber bumpers.
  • We find eight Phillips screws holding the case together.
  • After removing the screws, we use picks to remove the lower case which is held in with clips.
Agregar Comentario
Lower case is removed to view the internals.
  • Lower case is removed to view the internals.
Agregar Comentario
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Battery comes out easily—just 6 screws and a connector on the motherboard. SSD is standard and user-upgradable. RAM is also standard and user-upgradable.
  • Battery comes out easily—just 6 screws and a connector on the motherboard.
  • SSD is standard and user-upgradable.
  • RAM is also standard and user-upgradable.
  • At this time, it's cool to note that you can remove the display assembly, speakers, daughterboard, backup battery, motherboard, trackpad, and the fan.
    • Perhaps slightly more useful knowledge: The only component we cannot remove is the keyboard.
Agregar Comentario
We chose the fan + heatpipe combo. 7 screws and 1 plug Followed closely by the motherboard. No surprises. In total < 10 screws, exactly 6 connectors, and the wireless card. There were some alignment pins that required a tiny bit of finagling, but if you know they're there this will take you less than a minute.
  • We chose the fan + heatpipe combo. 7 screws and 1 plug
  • Followed closely by the motherboard. No surprises. In total < 10 screws, exactly 6 connectors, and the wireless card.
    • There were some alignment pins that required a tiny bit of finagling, but if you know they're there this will take you less than a minute.
  • Trackpad's next. It's held in with 4 screws and pops out the top of the lower case.
Is the CPU easily removable from the motherboard or is it soldered? In other words, is the processory/chip user-upgradable? Thank you -
ken maready - Contestar
I/O board, wireless card, speakers, and CMOS battery. The speakers were held in with adhesive to supplement a pair of screws, but it peeled off the case cleanly and we could reuse it when reassembling the unit.
  • I/O board, wireless card, speakers, and CMOS battery.
  • The speakers were held in with adhesive to supplement a pair of screws, but it peeled off the case cleanly and we could reuse it when reassembling the unit.
INTEL® DUAL BAND WIRELESS-AC 7265 is M.2 1216 or M.2 2230?
Miguel Gandara - Contestar
Keyboard is hidden beneath thin-film insulator taped in place. If you're performing a keyboard replacement, you'll need to buy replacement adhesive for this film. It's is held in place with 48 screws, which sounds bad, but is par for the course for a repairable laptop. Here, the lack of glue in a laptop this compact is practically a miracle. It's is held in place with 48 screws, which sounds bad, but is par for the course for a repairable laptop. Here, the lack of glue in a laptop this compact is practically a miracle.
  • Keyboard is hidden beneath thin-film insulator taped in place. If you're performing a keyboard replacement, you'll need to buy replacement adhesive for this film.
  • It's is held in place with 48 screws, which sounds bad, but is par for the course for a repairable laptop. Here, the lack of glue in a laptop this compact is practically a miracle.
Agregar Comentario
Four screws later, the display assembly is free from the lower case.
  • Four screws later, the display assembly is free from the lower case.
Agregar Comentario
The LG Gram 15&quot; earns a 9 out of 10 on our repairability scale (10 is the easiest to repair): Most components are immediately accessible after removing the lower case cover.
  • The LG Gram 15" earns a 9 out of 10 on our repairability scale (10 is the easiest to repair):
    • Most components are immediately accessible after removing the lower case cover.
    • RAM and SSD are user-replaceable and parts for upgrades are readily accessible.
    • Battery is also user-replaceable.
    • Only Phillips screws are used throughout the device.
    • Manufacturer does not provide user-accessible repair documentation.
Agregar Comentario
Linea de Meta
Una persona más ha completado esta guía.
Jeff Suovanen
Miembro Desde 06/08/13
161,180 Reputación
410 Guías creadas
Equipo
iFixit Miembro de iFixit
Community
114 Miembros
5,902 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 24
Últimos 7 Días: 127
Últimos 30 Días: 601
Todo El Tiempo: 5,135
