Saltar al contenido principal
LG G Stylo Battery Replacement
Qué necesitas
  1. LG G Stylo Battery Replacement, Battery: paso 1, imagen 1 de 2 LG G Stylo Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Make sure that you power off the phone before beginning.
    • Remove the back cover by placing the plastic opening tool on the bottom left side of the device and gently prying up.
    • There is a small slit that fits the plastic opening tool perfectly on the left side.
  2. LG G Stylo Battery Replacement: paso 2, imagen 1 de 2 LG G Stylo Battery Replacement: paso 2, imagen 2 de 2
    • Insert the plastic opening tool into the indent at the bottom of the battery and lift up. Fully remove the battery with your fingers.
Conclusión
6 personas más completaron esta guía.
Equipo
USF Tampa, Team 11-7, Cheng Spring 2016 Miembro de USF Tampa, Team 11-7, Cheng Spring 2016
USFT-CHENG-S16S11G7
4 Miembros
14 Guías creadas
Un comentario
Thank you for your help. This has been making us crazy, your time is much appreciated.
Desi Young - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 10
Ultimos 30 días: 61
Todo El Tiempo: 12,853
