Saltar al contenido principal
LG Dare Digitizer Replacement
Qué necesitas
  1. LG Dare Digitizer Replacement, Battery: paso 1, imagen 1 de 2 LG Dare Digitizer Replacement, Battery: paso 1, imagen 2 de 2
    • Remove the back cover by firmly pressing against the raised lip on the back panel. Slide the cover towards the top of the phone.
  2. LG Dare Digitizer Replacement: paso 2, imagen 1 de 3 LG Dare Digitizer Replacement: paso 2, imagen 2 de 3 LG Dare Digitizer Replacement: paso 2, imagen 3 de 3
    • Remove the battery by placing your fingernail or a opening tool in the recessed edge and lift the battery out.
  3. LG Dare Digitizer Replacement, Logic Board: paso 3, imagen 1 de 2 LG Dare Digitizer Replacement, Logic Board: paso 3, imagen 2 de 2
    • Use the #00 screwdriver to remove the six 4mm phillips screws located around the edges of the phone.
  4. LG Dare Digitizer Replacement: paso 4, imagen 1 de 3 LG Dare Digitizer Replacement: paso 4, imagen 2 de 3 LG Dare Digitizer Replacement: paso 4, imagen 3 de 3
    • Lift the back plastic cover off by moving the opening tool around the edges of the phone.
    • Wedging the opening tool in several places on the bottom of the phone will help release small tabs that hold the back to the front frame.
    • The side buttons may fall out when removing the back plastic.
  5. LG Dare Digitizer Replacement: paso 5, imagen 1 de 3 LG Dare Digitizer Replacement: paso 5, imagen 2 de 3 LG Dare Digitizer Replacement: paso 5, imagen 3 de 3
    • Pull off the back plastic panel.
    • Remove the buttons from the edge of the frame. The buttons are [lock], [volume control], [speaker], and [camera].
  6. LG Dare Digitizer Replacement: paso 6, imagen 1 de 1
    • Disconnect the three ribbon connectors from the motherboard.
  7. LG Dare Digitizer Replacement: paso 7, imagen 1 de 3 LG Dare Digitizer Replacement: paso 7, imagen 2 de 3 LG Dare Digitizer Replacement: paso 7, imagen 3 de 3
    • Remove the LED.
    • Remove the camera connector.
    • Remove the camera sensor from the logic board. Squeeze the sides of the camera sensor firmly and pull straight up.
  8. LG Dare Digitizer Replacement: paso 8, imagen 1 de 1
    • Open the USB port cover.
  9. LG Dare Digitizer Replacement: paso 9, imagen 1 de 3 LG Dare Digitizer Replacement: paso 9, imagen 2 de 3 LG Dare Digitizer Replacement: paso 9, imagen 3 de 3
    • Use the opening tool to lift up the green logic board in all areas and remove it.
    • The logic board may require some force to remove because it is taped to the plastic frame.
    • When removing the logic board, be careful not to tear any of the ribbon cables or side buttons.
  10. LG Dare Digitizer Replacement, Earpiece: paso 10, imagen 1 de 3 LG Dare Digitizer Replacement, Earpiece: paso 10, imagen 2 de 3 LG Dare Digitizer Replacement, Earpiece: paso 10, imagen 3 de 3
    • Peel off the gold and green tape near the bottom of the phone.
    • Peel off the blue tape covering the speaker connector.
    • Peel off the gold tape to the left of the earpiece speaker.
    • It is unnecessary to remove the blue and gold tape from the device if the speaker is not being removed.
  11. LG Dare Digitizer Replacement: paso 11, imagen 1 de 2 LG Dare Digitizer Replacement: paso 11, imagen 2 de 2
    • Lift up the orange ribbon cable in the bottom left corner of the device.
    • Peel off the small piece of gold tape underneath the orange component back.
  12. LG Dare Digitizer Replacement: paso 12, imagen 1 de 2 LG Dare Digitizer Replacement: paso 12, imagen 2 de 2
    • Undo the clips that attach the black plastic strip to the frame of the phone.
    • Pry the plastic strip away from the phone, using an opening tool, until it detaches.
  13. LG Dare Digitizer Replacement: paso 13, imagen 1 de 2 LG Dare Digitizer Replacement: paso 13, imagen 2 de 2
    • Pry the button panel from the device, starting where the screen and panel connect, until the panel detaches.
  14. LG Dare Digitizer Replacement: paso 14, imagen 1 de 2 LG Dare Digitizer Replacement: paso 14, imagen 2 de 2
    • Rotate the phone upside down with the back facing you.
    • Using your finger to hold the bottom connector in place, use the opening tool to remove the top connector.
  15. LG Dare Digitizer Replacement: paso 15, imagen 1 de 3 LG Dare Digitizer Replacement: paso 15, imagen 2 de 3 LG Dare Digitizer Replacement: paso 15, imagen 3 de 3
    • Using the opening tool, pry the frame from the device, starting at the open edges at the bottom of the device, and working your way around.
    • Do not detach the frame yet.
  16. LG Dare Digitizer Replacement: paso 16, imagen 1 de 3 LG Dare Digitizer Replacement: paso 16, imagen 2 de 3 LG Dare Digitizer Replacement: paso 16, imagen 3 de 3
    • Gently separate the top of the frame from the back of the device, without completely detaching at the bottom, as shown in the third picture.
  17. LG Dare Digitizer Replacement: paso 17, imagen 1 de 2 LG Dare Digitizer Replacement: paso 17, imagen 2 de 2
    • Remove both connectors from the frame. Fold back the L-shaped connector and slide the second connector through the hole in the metal frame.
    • Remove the frame from the plastic panel.
    • The next two steps are for earpiece removal only.
  18. LG Dare Digitizer Replacement: paso 18, imagen 1 de 2 LG Dare Digitizer Replacement: paso 18, imagen 2 de 2
    • Using the opening tool, pry the orange connector pad that is securing the earpiece to the frame, away from the device, until it detaches.
    • It may be necessary to apply more force to remove the pad because it is taped to the frame.
  19. LG Dare Digitizer Replacement: paso 19, imagen 1 de 2 LG Dare Digitizer Replacement: paso 19, imagen 2 de 2
    • Pry the rest of the orange connector pad --on the opposite side of the device-- away from the frame, and carefully remove the entire earpiece.
  20. LG Dare Digitizer Replacement, Screen: paso 20, imagen 1 de 2 LG Dare Digitizer Replacement, Screen: paso 20, imagen 2 de 2
    • Lift all four corners of the screen.
    • Being too aggressive could damage the screen.
  21. LG Dare Digitizer Replacement: paso 21, imagen 1 de 2 LG Dare Digitizer Replacement: paso 21, imagen 2 de 2
    • Remove the screen from the digitizer.
  22. LG Dare Digitizer Replacement, Digitizer: paso 22, imagen 1 de 3 LG Dare Digitizer Replacement, Digitizer: paso 22, imagen 2 de 3 LG Dare Digitizer Replacement, Digitizer: paso 22, imagen 3 de 3
    • Using the opening tool, carefully pry the digitizer (the black-rimmed piece) away from the silver frame.
    • Remove the digitizer carefully without breaking the connector.
    • Be careful when removing the digitizer because it is glued to the front panel. It may be necessary to apply more force or use a blow dryer to loosen the glue.
  23. LG Dare Digitizer Replacement: paso 23, imagen 1 de 1
    • Carefully remove the digitizer connector from the plastic frame. There is a slot that the connector slides through.
Conclusión
To re-assemble your device, follow these instructions in reverse order.
Una persona más ha completado esta guía.
Haoyan Huang
Miembro Desde 01/26/12
139 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 9-4, Regan Winter 2012 Miembro de Cal Poly, Team 9-4, Regan Winter 2012
CPSU-REGAN-W12S9G4
5 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 14
Todo El Tiempo: 5,208
