Find a sliding button on the lower back side of the device and with your finger, slide it to the left firmly. The battery should pop out fairly easily. If not, slide the button further or grab and pull it while sliding the button.
  • Find a sliding button on the lower back side of the device and with your finger, slide it to the left firmly.
    • The battery should pop out fairly easily. If not, slide the button further or grab and pull it while sliding the button.
Agregar Comentario
Unscrew the four Phillips 00 screws on the four corners under the battery to unfasten the back case from the phone.
  • Unscrew the four Phillips 00 screws on the four corners under the battery to unfasten the back case from the phone.
Agregar Comentario
Pry the case off using a plastic opening tool. Continue working the plastic opening tool around the sides of the device, unhooking the eight tabs securing the back cover to the rest of the phone as shown in the second photo. The back speaker will be connected to the motherboard, and must be disconnected to remove the case.
  • Pry the case off using a plastic opening tool.
    • Continue working the plastic opening tool around the sides of the device, unhooking the eight tabs securing the back cover to the rest of the phone as shown in the second photo.
    • The back speaker will be connected to the motherboard, and must be disconnected to remove the case.
Agregar Comentario
Unscrew the 4 Phillips 00 screws that connect the two halves of the phone together.
  • Unscrew the 4 Phillips 00 screws that connect the two halves of the phone together.
Agregar Comentario
Between the two halves is a ribbon. Use a plastic opening tool to flip up the lock and disconnect it. Between the two halves is a ribbon. Use a plastic opening tool to flip up the lock and disconnect it.
  • Between the two halves is a ribbon. Use a plastic opening tool to flip up the lock and disconnect it.
Agregar Comentario
Pry off the plastic tabs that cover two screws, as shown in the first picture. Then, remove the 6 Phillips 00 screws from the back of the case, as shown in the second picture.
  • Pry off the plastic tabs that cover two screws, as shown in the first picture.
    • Then, remove the 6 Phillips 00 screws from the back of the case, as shown in the second picture.
Agregar Comentario
Pry off the back cover from the front of the case using a plastic opening tool.
  • Pry off the back cover from the front of the case using a plastic opening tool.
Agregar Comentario
Pry the front speaker and wireless receiver out of the front case using a spudger. They may be taped into the case, so don't be afraid to pry hard. They may be taped into the case, so don't be afraid to pry hard.
  • Pry the front speaker and wireless receiver out of the front case using a spudger.
    • They may be taped into the case, so don't be afraid to pry hard.
Agregar Comentario
Starting with the side that has the speaker and receiver, carefully lift the LCD Board out of the case. Starting with the side that has the speaker and receiver, carefully lift the LCD Board out of the case.
  • Starting with the side that has the speaker and receiver, carefully lift the LCD Board out of the case.
Agregar Comentario
Unhook the ribbon cable using that flat side of a spudger.
  • Unhook the ribbon cable using that flat side of a spudger.
Agregar Comentario
Next, carefully remove the tape from the LCD board.
  • Next, carefully remove the tape from the LCD board.
Agregar Comentario
Finally, flip up the black switch to unhook the LCD screen from the LCD board using a spudger. The LCD Board in now accessible.
  • Finally, flip up the black switch to unhook the LCD screen from the LCD board using a spudger.
  • The LCD Board in now accessible.
Agregar Comentario
The side buttons can now be accessed freely.
  • The side buttons can now be accessed freely.
Agregar Comentario
Conclusión
Charles Yoon
Miembro Desde 18/01/13
61 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 19-46, Regan Winter 2013 Miembro de Cal Poly, Team 19-46, Regan Winter 2013
CPSU-REGAN-W13S19G46
4 Miembros
22 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 105
