Introducción
Restore sound to your phone by replacng the speaker.
Use your thumb to press down and slide off the back cover of the phone. Use your thumb to press down and slide off the back cover of the phone.
  • Use your thumb to press down and slide off the back cover of the phone.
Agregar Comentario
Take out the battery by levering it out towards the bottom of the phone. Take out the battery by levering it out towards the bottom of the phone. Take out the battery by levering it out towards the bottom of the phone.
  • Take out the battery by levering it out towards the bottom of the phone.
Agregar Comentario
Push the spudger between each of the two rubber cushions and the body of the phone. Then turn the spudger to pop each cushion out.
  • Push the spudger between each of the two rubber cushions and the body of the phone. Then turn the spudger to pop each cushion out.
Agregar Comentario
Remove six 3.0 mm Phillips #00 screws from the back of the phone.
  • Remove six 3.0 mm Phillips #00 screws from the back of the phone.
Agregar Comentario
Push the spudger into the crack separating the two pieces of the phone. Then use the plastic opening tools to pry the back off by separating the two pieces of the phone. Repeat as necessary around the perimeter of the phone until the casing pops off. Use force as necessary without breaking the cover.
  • Push the spudger into the crack separating the two pieces of the phone.
  • Then use the plastic opening tools to pry the back off by separating the two pieces of the phone.
  • Repeat as necessary around the perimeter of the phone until the casing pops off. Use force as necessary without breaking the cover.
  • The back is attached to the motherboard by a wire, so don't pull the back casing off just yet.
Agregar Comentario
Gently pull the wire up from the motherboard, separating the back of the phone and the motherboard.
  • Gently pull the wire up from the motherboard, separating the back of the phone and the motherboard.
Agregar Comentario
Remove the plastic tab connecting the screen to the motherboard by pulling the tab up from the board.
  • Remove the plastic tab connecting the screen to the motherboard by pulling the tab up from the board.
Agregar Comentario
Gently grasp one of the corners of the motherboard and simply lift it straight up out of the phone casing.
  • Gently grasp one of the corners of the motherboard and simply lift it straight up out of the phone casing.
  • Replace the motherboard with a new one.
Agregar Comentario
Remove the speaker component from the back of the phone by lifting up the top part to a 45 degree angle and pulling it out. Remove the speaker component from the back of the phone by lifting up the top part to a 45 degree angle and pulling it out.
  • Remove the speaker component from the back of the phone by lifting up the top part to a 45 degree angle and pulling it out.
Agregar Comentario
Pull speaker out of the component by grabbing the wire attached to it in order to replace it.
  • Pull speaker out of the component by grabbing the wire attached to it in order to replace it.
Agregar Comentario
Conclusión
Zack Mintzer
Miembro Desde 16/04/13
1 Reputación
12 Guías creadas
Equipo
Cal Poly, Team 21-55, Johann Spring 2013 Miembro de Cal Poly, Team 21-55, Johann Spring 2013
CPSU-JOHANN-S13S21G55
4 Miembros
12 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 271
