Introducción
How to remove the keypad from an LG CG180 cell phone.
Power down the cell phone by pressing and holding down the red "end call" button.
  • Power down the cell phone by pressing and holding down the red "end call" button.
Agregar Comentario
Turn the phone screen-down so you are looking at the back cover.
  • Turn the phone screen-down so you are looking at the back cover.
Agregar Comentario
Slide the back cover down using your finger to remove the cover from the phone. Slide the back cover down using your finger to remove the cover from the phone.
  • Slide the back cover down using your finger to remove the cover from the phone.
Agregar Comentario
Place your finger at the top of the battery in small gap.
  • Place your finger at the top of the battery in small gap.
Agregar Comentario
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Press downward while pulling outward to remove the battery.
  • Press downward while pulling outward to remove the battery.
Agregar Comentario
Remove all four screws on the back of the phone using a Phillips #00 screwdriver.
  • Remove all four screws on the back of the phone using a Phillips #00 screwdriver.
Agregar Comentario
Insert a plastic opening tool in the seam.
  • Insert a plastic opening tool in the seam.
Agregar Comentario
Run the tool along the seam to release all the tabs. Run the tool along the seam to release all the tabs.
  • Run the tool along the seam to release all the tabs.
Agregar Comentario
Pull the phone back cover off once all the tabs are released. Pull the phone back cover off once all the tabs are released.
  • Pull the phone back cover off once all the tabs are released.
Agregar Comentario
Push the contents of the phone away from the hardshell case by applying pressure to the keypad with both thumbs.
  • Push the contents of the phone away from the hardshell case by applying pressure to the keypad with both thumbs.
Agregar Comentario
The hardshell case is separated from the rest of the phone.
  • The hardshell case is separated from the rest of the phone.
Agregar Comentario
Separate keypad from circuit board by turning it upside down and allowing it to fall off. Separate keypad from circuit board by turning it upside down and allowing it to fall off.
  • Separate keypad from circuit board by turning it upside down and allowing it to fall off.
Agregar Comentario
Conclusión
Alex Jacobs
Miembro Desde 21/01/10
5 Reputación
8 Guías creadas
Equipo
Cal Poly, Team 14-42, Regan Winter 2010 Miembro de Cal Poly, Team 14-42, Regan Winter 2010
CPSU-REGAN-W10S14G42
4 Miembros
10 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 1,313
