Saltar al contenido principal
LG CG180 Hardshell Case Replacement
Qué necesitas
  1. LG CG180 Hardshell Case Replacement, Battery: paso 1, imagen 1 de 1
    • Power down the cell phone by pressing and holding down the red "end call" button.
  2. LG CG180 Hardshell Case Replacement: paso 2, imagen 1 de 1
    • Turn the phone screen-down so you are looking at the back cover.
  3. LG CG180 Hardshell Case Replacement: paso 3, imagen 1 de 2 LG CG180 Hardshell Case Replacement: paso 3, imagen 2 de 2
    • Slide the back cover down using your finger to remove the cover from the phone.
  4. LG CG180 Hardshell Case Replacement: paso 4, imagen 1 de 1
    • Place your finger at the top of the battery in small gap.
  5. LG CG180 Hardshell Case Replacement: paso 5, imagen 1 de 1
    • Press downward while pulling outward to remove the battery.
  6. LG CG180 Hardshell Case Replacement, Hardshell Case: paso 6, imagen 1 de 1
    • Remove all four screws on the back of the phone using a Phillips #00 screwdriver.
  7. LG CG180 Hardshell Case Replacement: paso 7, imagen 1 de 1
    • Insert a plastic opening tool in the seam.
  8. LG CG180 Hardshell Case Replacement: paso 8, imagen 1 de 2 LG CG180 Hardshell Case Replacement: paso 8, imagen 2 de 2
    • Run the tool along the seam to release all the tabs.
  9. LG CG180 Hardshell Case Replacement: paso 9, imagen 1 de 2 LG CG180 Hardshell Case Replacement: paso 9, imagen 2 de 2
    • Pull the phone back cover off once all the tabs are released.
  10. LG CG180 Hardshell Case Replacement: paso 10, imagen 1 de 1
    • Push the contents of the phone away from the hardshell case by applying pressure to the keypad with both thumbs.
  11. LG CG180 Hardshell Case Replacement: paso 11, imagen 1 de 1
    • The hardshell case is separated from the rest of the phone.
Conclusión
Equipo
Cal Poly, Team 14-42, Regan Winter 2010 Miembro de Cal Poly, Team 14-42, Regan Winter 2010
CPSU-REGAN-W10S14G42
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 1,765
