Saltar al contenido principal
LCD LG 37LF65 Capacitor replacement
Qué necesitas
  1. LCD LG 37LF65 Capacitor replacement, Open the case: paso 1, imagen 1 de 1
    • Power off and unplug your device before starting this repair.
    • Open the case carefully while loosing the marked srews.
  2. LCD LG 37LF65 Capacitor replacement, Replace the capacitors: paso 2, imagen 1 de 1
    • Check the power-board. If there are any blown-up capacitors, you should replace them.
    • For removing the capacitors, remove the board, take a soldering bolt and heat the solder points at the back of the board.
    • Insert the replacement capacitors and solder it. Check the poles!
  3. LCD LG 37LF65 Capacitor replacement, Testing capacitors: paso 3, imagen 1 de 1
    • If you are not sure about the condition of the capacitors you can prove it with a good measuring device after the expansion.
Conclusión
Not all capacitors are need in any case. To reassemble your device, follow these instructions in reverse order.
9 personas más completaron esta guía.
eugl18
Miembro Desde 01/18/13
561 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 10
Ultimos 30 días: 40
Todo El Tiempo: 13,343
