Saltar al contenido principal
Kodak S100 EF Front Cover Replacement
Qué necesitas
  1. Kodak S100 EF Front Cover Replacement, Front Cover: paso 1, imagen 1 de 1
    • Have the camera facing upwards and the flash closest to you.
    • Unscrew the two 6.2 mm Phillips screws on the top half of the camera.
  2. Kodak S100 EF Front Cover Replacement: paso 2, imagen 1 de 1
    • Flip the camera over to the other side-with flash farthest from you.
    • Unscrew top two 6.2mm Phillips screws on this side.
  3. Kodak S100 EF Front Cover Replacement: paso 3, imagen 1 de 1
    • Turn the camera so the bottom is facing up with the front-facing away.
    • Unscrew the 6.2mm Phillips screw on the top right.
    • The front cover is now unscrewed and should be lifted evenly and removed.
Conclusión
Michelle
Miembro Desde 04/04/11
107 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 25-28, Garner Spring 2011 Miembro de Cal Poly, Team 25-28, Garner Spring 2011
CPSU-GARNER-S11S25G28
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 1,993
