Introducción
To start, the Front Cover Teardown guide must be used. Later, soldering guides will be used.
Partes
No se requieren partes.
Have the camera facing up and the flash closest to you.
  • Have the camera facing up and the flash closest to you.
  • Unscrew the two 6.2 mm Phillips screws on the top half of the camera.
Agregar Comentario
Flip camera to other side-with flash farthest from you.
  • Flip camera to other side-with flash farthest from you.
  • Unscrew top two 6.2mm Phillips screws on this side.
Agregar Comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
Turn the camera so the bottom is facing up with the front facing away.
  • Turn the camera so the bottom is facing up with the front facing away.
  • Unscrew the 6.2mm Phillips screw on the top right.
  • The front cover is now unscrewed and should be lifted up evenly and removed.
Agregar Comentario
Once the front cover is off, desolder the connections at both ends of the flash.
Agregar Comentario
Conclusión
Nick
Miembro Desde 26/04/11
1 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 25-28, Garner Spring 2011 Miembro de Cal Poly, Team 25-28, Garner Spring 2011
CPSU-GARNER-S11S25G28
4 Miembros
6 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 6
Todo El Tiempo: 1,476
