Saltar al contenido principal
Kodak S100 EF Flash Capacitor Replacement
Qué necesitas
  1. Kodak S100 EF Flash Capacitor Replacement, Back Cover: paso 1, imagen 1 de 2 Kodak S100 EF Flash Capacitor Replacement, Back Cover: paso 1, imagen 2 de 2
    • Remove the two 6.2mm Phillips screws on both sides of camera's back cover.
  2. Kodak S100 EF Flash Capacitor Replacement: paso 2, imagen 1 de 1
    • Turn camera so the bottom is facing up and the front is facing away.
    • Remove the two 6.2mm Phillips screws on the bottom back cover of the camera.
    • Back cover is now unscrewed an can be removed.
  3. Kodak S100 EF Flash Capacitor Replacement: paso 3, imagen 1 de 1
    • Have the back of the camera facing up.
    • Unscrew the 6.2mm Phillips screw next to the viewfinder.
    • The back cover is now unscrewed. Lift up and pull the cover off evenly.
  4. Kodak S100 EF Flash Capacitor Replacement, Flash Capacitor: paso 4, imagen 1 de 1
    • The capacitor is located at the bottom center of the camera.
  5. Kodak S100 EF Flash Capacitor Replacement: paso 5, imagen 1 de 1
Conclusión
Michelle
Miembro Desde 04/04/11
107 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 25-28, Garner Spring 2011 Miembro de Cal Poly, Team 25-28, Garner Spring 2011
CPSU-GARNER-S11S25G28
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 5
Todo El Tiempo: 2,351
