Introducción
The internal frame of the Kodak EasyShare Z1015 IS separates the logic board from the LCD screen. To remove it from the camera, follow this guide.
Partes
No se requieren partes.
Begin by sliding the switch towards the open symbol. Release your finger from the switch and the battery case will pop open. Begin by sliding the switch towards the open symbol. Release your finger from the switch and the battery case will pop open.
  • Begin by sliding the switch towards the open symbol. Release your finger from the switch and the battery case will pop open.
Agregar Comentario
Next, press down on the red lever which holds the battery in place.
  • Next, press down on the red lever which holds the battery in place.
Agregar Comentario
Once the battery has popped out of the compartment, simply pull it out of the camera. Once the battery has popped out of the compartment, simply pull it out of the camera.
  • Once the battery has popped out of the compartment, simply pull it out of the camera.
Agregar Comentario
Make sure that the lens cover is on the Kodak EasyShare whenever working with one of these guides. Also, make sure to keep track of the screws you remove throughout these step by step guides. Losing a screw could inhibit the ability to reassemble the camera. Begin by removing the first screw located on the back of the camera.
  • Make sure that the lens cover is on the Kodak EasyShare whenever working with one of these guides.
  • Also, make sure to keep track of the screws you remove throughout these step by step guides. Losing a screw could inhibit the ability to reassemble the camera.
  • Begin by removing the first screw located on the back of the camera.
Agregar Comentario
Next, remove the two screws located on the right side of the camera. Next, remove the two screws located on the right side of the camera.
  • Next, remove the two screws located on the right side of the camera.
Agregar Comentario
After removing the screws located on the right side, remove the six screws located on the bottom of the camera. After removing the screws located on the right side, remove the six screws located on the bottom of the camera.
  • After removing the screws located on the right side, remove the six screws located on the bottom of the camera.
Agregar Comentario
Lastly, remove the two screws located on the left side of the camera. Lastly, remove the two screws located on the left side of the camera.
  • Lastly, remove the two screws located on the left side of the camera.
Agregar Comentario
Once all eleven screws have been removed, use Plastic Opening Tools to take off the back cover. Insert the plastic opening tool and apply leverage on each side of the camera. The recommended spots to apply leverage are shown in these pictures. Insert the plastic opening tool and apply leverage on each side of the camera. The recommended spots to apply leverage are shown in these pictures.
  • Once all eleven screws have been removed, use Plastic Opening Tools to take off the back cover.
    • Insert the plastic opening tool and apply leverage on each side of the camera. The recommended spots to apply leverage are shown in these pictures.
Agregar Comentario
Apply pressure on the left and right side of the camera and pull the back cover away from the device. Once the back cover has been successfully removed, you should have a total of eleven screws as well as the bottom cover separated from the camera. Once the back cover has been successfully removed, you should have a total of eleven screws as well as the bottom cover separated from the camera.
  • Apply pressure on the left and right side of the camera and pull the back cover away from the device.
  • Once the back cover has been successfully removed, you should have a total of eleven screws as well as the bottom cover separated from the camera.
Agregar Comentario
Begin by using Plastic Opening Tools to remove the LCD Screen from it's interior casing. To do this, place the opening tool in between the screen and casing and apply leverage to remove the screen. Do this around the rim of the casing, especially where orange squares appear in the pictures. Begin by using Plastic Opening Tools to remove the LCD Screen from it's interior casing. To do this, place the opening tool in between the screen and casing and apply leverage to remove the screen. Do this around the rim of the casing, especially where orange squares appear in the pictures.
  • Begin by using Plastic Opening Tools to remove the LCD Screen from it's interior casing. To do this, place the opening tool in between the screen and casing and apply leverage to remove the screen. Do this around the rim of the casing, especially where orange squares appear in the pictures.
Agregar Comentario
Gently remove the LCD screen from it's interior casing by lifting and pulling from the right side.
  • Gently remove the LCD screen from it's interior casing by lifting and pulling from the right side.
  • Be incredibly cautious not to pull to hard on the screen, doing so may rip the ribbon that connects the screen to the logic board and permanently damage your camera.
Agregar Comentario
To completely remove the LCD screen from the interior of the camera, you must unhook the ribbon from the logic board. To do this, simply lift up the tab connecting the ribbon to the logic board and pull gently on the LCD screen. To do this, simply lift up the tab connecting the ribbon to the logic board and pull gently on the LCD screen.
  • To completely remove the LCD screen from the interior of the camera, you must unhook the ribbon from the logic board.
  • To do this, simply lift up the tab connecting the ribbon to the logic board and pull gently on the LCD screen.
Agregar Comentario
Begin by unscrewing all four screws found in each corner of the frame Begin by unscrewing all four screws found in each corner of the frame Begin by unscrewing all four screws found in each corner of the frame
  • Begin by unscrewing all four screws found in each corner of the frame
Agregar Comentario
Next, use Plastic Opening Tools to loosen the frame from the camera. Do this by placing the tool in between the frame and the camera and applying leverage.
  • Next, use Plastic Opening Tools to loosen the frame from the camera. Do this by placing the tool in between the frame and the camera and applying leverage.
  • Avoid placing the opening tool in between the frame and camera on the bottom side of the device. There is ribbon there that could easily be damaged if not carefully avoided.
Agregar Comentario
After loosening the frame with the opening tools, gently remove the frame from the interior of the camera. After loosening the frame with the opening tools, gently remove the frame from the interior of the camera.
  • After loosening the frame with the opening tools, gently remove the frame from the interior of the camera.
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Jack
Miembro Desde 10/10/10
172 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 5-16, Maness Fall 2010 Miembro de Cal Poly, Team 5-16, Maness Fall 2010
CPSU-MANESS-F10S5G16
4 Miembros
6 Guías creadas
I have a Kodac DX7630 and a Kodac DX4530 both with the same problem..the monitor is black.The rest functions perfectly.Cam they be repaired and will there still be parts available?
Many thanks
Denzil
Denzil Terblanche - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 2
Últimos 7 Días: 2
Últimos 30 Días: 9
Todo El Tiempo: 2,472
