Introducción
Replace unusable or damaged button.
Partes
No se requieren partes.
Open the battery cover.
  • Open the battery cover.
Agregar Comentario
Slide the orange latch sideways to eject the battery.
  • Slide the orange latch sideways to eject the battery.
  • Remove the battery.
Agregar Comentario
Remove 7 screws. 1 (6.25 mm) screw located on the top right corner, next to the view screen. 4 (4.45mm) screws on the bottom of the camera.
  • Remove 7 screws.
    • 1 (6.25 mm) screw located on the top right corner, next to the view screen.
    • 4 (4.45mm) screws on the bottom of the camera.
    • 2 (2.95mm) screws on the left side of the camera.
Agregar Comentario
There will be 2 (5.39mm) screws. Remove the screws in order to remove the lanyard. There will be 2 (5.39mm) screws. Remove the screws in order to remove the lanyard. There will be 2 (5.39mm) screws. Remove the screws in order to remove the lanyard.
  • There will be 2 (5.39mm) screws. Remove the screws in order to remove the lanyard.
Agregar Comentario
Remove the rear camera casing. Remove the front casing.
  • Remove the rear camera casing.
  • Remove the front casing.
Agregar Comentario
Remove the top panel screw (1x 4.37mm). Remove the top panel screw (1x 4.37mm).
  • Remove the top panel screw (1x 4.37mm).
Agregar Comentario
Remove the top panel. Remove the top panel.
  • Remove the top panel.
Agregar Comentario
Remove the back panel screws (1x 3.33mm, and  1x 3.40mm). Remove the back panel screws (1x 3.33mm, and  1x 3.40mm).
  • Remove the back panel screws (1x 3.33mm, and 1x 3.40mm).
Agregar Comentario
Separate the inner casing  from the tripod mount. Separate the inner casing  from the tripod mount. Separate the inner casing  from the tripod mount.
  • Separate the inner casing from the tripod mount.
Agregar Comentario
Gently pull the  orange tab out of the  circuit board. Gently pull the  orange tab out of the  circuit board. Gently pull the  orange tab out of the  circuit board.
  • Gently pull the orange tab out of the circuit board.
Agregar Comentario
Carefully flip the LCD panel to expose the central circuit board. Carefully flip the LCD panel to expose the central circuit board.
  • Carefully flip the LCD panel to expose the central circuit board.
Agregar Comentario
Remove the (1x 3.33mm) screw from the menu button panel .
  • Remove the (1x 3.33mm) screw from the menu button panel .
Agregar Comentario
Pull the second orange tab from the circuit board and remove the buttons. Pull the second orange tab from the circuit board and remove the buttons.
  • Pull the second orange tab from the circuit board and remove the buttons.
Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Michael
Miembro Desde 24/06/10
63 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 2-8, Johann Summer 2010 Miembro de Cal Poly, Team 2-8, Johann Summer 2010
CPSU-JOHANN-R10S2G8
5 Miembros
8 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 1,197
